need help asap. Timing belt job
Old 09-15-2013, 08:04 AM
x19
x19's Avatar
Originally Posted by Huskerbob
I see your answer over at audiforums.com evidently there is a spacer on one of the pulleys that if removed will draw that belt up tight. Good luck.
Try to loosen all bolts on P/Steering pump and you will find the movement that you can stretch belt. This is only one place for adjusting the belt. x19
Old 09-15-2013, 04:01 PM
Jim4802's Avatar
It's back together now and seens to be working ok. I'll try the bolts later this week. I stripped a bolt in the crank pully and broke the new serp tensioner during the repair. spent most of the weekend in the garage. I'm tired! New timing belt, all other belts, WP, therm, pully's and tensioners, coolant, changed oil for under $225. Looking forward to work Monday. thanks for your help. Jim
lfrias
08-28-2010 08:44 AM
mattfl
TT (Mk1) Discussion
17
08-13-2007 03:19 PM
ozzie A 4
08-31-2005 11:25 AM
Clues
08-23-2002 05:02 AM
Quick Reply: need help asap. Timing belt job
