What should I expect to be problems on the 3.0 V6?
Old 10-09-2012, 04:38 PM
turbo510's Avatar
Default What should I expect to be problems on the 3.0 V6?
My Daughter has a 2005 3.0 with 110K miles, overdue for the "timing belt" job. She's had the car since 69K miles, and so far nothing to complain about. But I read of 3.0's being problem engines (4Driver4 has made mention, I think), and wanted some advice one what to watch out for as I collect parts for the service. My 12V 2.8 runs like a clock with over 225K miles, and I'd like this one to last too.
Old 10-10-2012, 04:10 AM
lyleswk's Avatar
As you probably know, been around the forum for almost 3 years and I sure haven't gotten the impression the 3.0 is a problem engine. It is complex and more expensive to repair than the 1.8t, but since you have had the car for a long while and maintained it well, it should last easily as long as your 2.8. If you see one or 2 people with issues, it is probably unique to that car and likely due to lack of proper maintenance.
Old 10-10-2012, 11:37 AM
Prospeeder's Avatar
Only things i ever see on 3.0 cars is Leaky valve covers, rotten vacuum hoses, and bad o2 sensor. None of which are really the engines fault
Old 10-23-2012, 07:20 PM
Reexx13's Avatar
Default audi a4 b6
i had recently purchased a audi a4 b6 with 3.0 v6...i was wondering what the common things i should change? its at 133k and he has done the timing belt, thermostat, and i believe the water pump since it was all near the area, and thing else i should be concerned of that should be changed? like how long do clutches last on these cars or transmission?
Old 10-24-2012, 03:43 AM
lyleswk's Avatar
Cluthces last as long as they last. What I mean by that, is it is totally dependent on the drive "cycle" (lots of highway, lots of stop and go, driver slipping the clutch, lots of racing starts, etc, etc). When you clutch takeup is very "high" in it travel, you know you are getting close.
rboater
12
01-14-2019 01:44 PM
PanzerWagon
01-16-2009 09:20 PM
A6 2.4 Multitronic
10-07-2004 07:00 PM
JamisonWescott
11-08-2002 03:08 PM
sgb
Misc. Models Discussion
01-11-2000 07:00 AM
Quick Reply: What should I expect to be problems on the 3.0 V6?
