Audi A8 - Auto Transmission Issues.
Old 06-07-2011, 02:53 PM
spitanddirt's Avatar
Did I not explain this adequately enough in my above post about why you may want to follow Tozo's advice and cut the pick-up tube so that it's farther away from the bottom of the pan?
Originally Posted by spitanddirt
As for the transmission --- I have something that you need to consider: did the transmission starve for fluid? I ask, because when I changed out my fluid on my trans and I replaced my filter, I noticed that the pickup tube was almost completely sealed off because the oil pan had been dented upwards. Normally, I have seen grooves pressed into transmission oil pans to prevent this from happening, but since you said the transmission had been rebuild I figure this is something you should check. Depending on who or how the transmission was installed, the oil pan could have been shoved upwards. Does the transmission pan have any noticable dents or other signs of abuse?
Think of it this way: it's just like holding your hand over a vacuum cleaner hose and then removing it. The vacuum motor's whine audibly changes because you have effectly made it work harder by not allowing air into the hose - little to no air flow. Only in this case, it's only air and it doesn't lubricate the vacuum's motor. In your transmission, suction for fluid is created by the transmission front pump, and it NEEDS fluid for lubrication.
Old 06-08-2011, 05:24 AM
chris.sargent's Avatar
Hey yeah, now worries, I understand that when we fit a new filter, we should shorten the pick up. I was more asking whether you think this would be related and actually causing the problems I'm having.
Popped in to a place called Revo Technik yesterday and told them what happened. They immediately asked 'what type of oil did they put in and is it full?' We showed them a sample of the oil we'd taken out, which is red and quite thin and again they immediately said it was totally the wrong oil, wrong colour and far too thin and watery. Explained that we might be able to save the box my doing a couple of full flushes and filter changes.
So next step is to contact the original garage who assured us they did it all properly and 'absolutely' used genuine Audi 'box oil - even listed the Audi part number on the invoice. Clearly they haven't so we will be asking for a refund, inconvenience compensation and that we will send a bill to them for a rebuilt box if we can't get this one going. Very frustrating when the guy supposedly worked for Audi for 20 years before setting up on his own (and this is the not the best sorts of things to be doing for your reputation when you're just starting out!) and assuring us he would do it right - we knew how sensitive these boxes were before doing it!
Depending on what they say and how they react, we may ask them to put it right or we just do it ourselves properly so we know it's been done to our standards!
Will update in a few days hopefully....
Old 06-08-2011, 08:54 AM
tozoM8's Avatar
Red doesn't mean it is a wrong fluid. I rebuild these transmissions and I only use red fluid. Most trans fluid is red. The free is important and the right type of fluid. Mobil 1 atf is good or any Mercon V fluid.
Old 06-08-2011, 03:29 PM
Originally Posted by chris.sargent
...... Very frustrating when the guy supposedly worked for Audi for 20 years before setting up on his own (and this is the not the best sorts of things to be doing for your reputation when you're just starting out!) and assuring us he would do it right - we knew how sensitive these boxes were before doing it!...
Sensitive? Hardly. You just happened to inherit the result of someone else's lack of preventitive maintenance or a technician's lack of following a manufacturer's techical data. As long as you aren't beating the crap out of a transmission by playing dragstrip driver at every stoplight, and assuming the transmission is assembled at the factory using parts that don't have any inherent weaknesses, an automatic transmission should last until the clutch linings physically wear out. This could be at least to 200K miles or more.
The whole reason you change the fluid out in the first place is to get rid of the debris and particulate matter that is so fine that it travels through the filter and acts as sandpaper on ultra high tolerance, precision fitted parts(valve body). After 90,000 miles, I'd say it's a pretty safe bet that the fluid is pretty well reached it's saturation point of contamination.
Just FYI, I'm not a professional transmission rebuilder, however, I did work for one disassembling large Allison transmissions to salvage good parts. I learned a lot from the other techs there about why transmissions fail and I've applied that knowledge to any transmission I do work on now.
Old 06-09-2011, 02:29 AM
I mean sensitive to the oil that's in it - e.g. the advice of using only Audi or other approved oils having the correct specifications, not just any old DXIII from Halfords.
Dewsoetz
New Member Welcome Area
08-15-2017 11:08 PM
Sarelvdh
05-10-2010 05:11 AM
spidermike
09-26-2005 12:28 AM
peternya8
9
07-12-2005 05:27 PM
coocoomike
03-25-2002 02:14 AM
Quick Reply: Audi A8 - Auto Transmission Issues.
