Sputters, loss of power and burning smell?
Old 04-26-2011, 11:42 AM
sachinsb's Avatar
Its not running rough, but the rpm just jumps up and drops down to normal without trnasfering the power to the wheels (like revving during idle).
I checked in autozone for the codes and i was told the code is related to MAF sensor.
-Sachin
Old 04-26-2011, 04:04 PM
sachinsb's Avatar
Sorry the code was P0411.
I got more information for the same code from
http://www.passatworld.com/forums/sh...d.php?t=170246
so posibility of rectifing the issue is by checking the combi-valve and air pump..
Old 04-27-2011, 04:08 AM
lyleswk's Avatar
Sounds like you are on the right track. Never assume the worst before eliminating the more simple.
Old 05-11-2011, 11:27 AM
Turtle Power's Avatar
sachinsb
I had MAF sensor too low code and it turned out almost all the secondary air circuit vacuum hoses were bad or plain off the connection points, this caused really rough driving and poor fuel economy. Could the burning smell be a leaking cam cover gasket - mine was leaking past this and dripping down the left side (looking from the front under the bonnet) which is the lowest side of the cam cover onto the exhaust manifold and i think the cat where it was burning off causing smoke and a bad smell in the car.
Essentially anything to do with MAF codes is a pain in the ... as the MAF may throw a code that relates to vacuum problems elsewhere but can easily be misinterpreted as a bad MAF.
Make sure all your vacuum hoses AND their clamps or connectors are sound - the clamps will let air in if they are not tight enough to create a seal.
Are you getting any coolant type warning lights or warnings either on the Driver Information System in the dash or codes in the memory?
snwyrvr
07-21-2015 10:19 AM
mawgui
07-29-2010 10:23 PM
higgies
13
01-20-2003 11:36 AM
KobeCow
08-20-2002 08:25 AM
AL B
Audi A3 / S3 / RS 3
19
07-07-2000 11:23 AM
Quick Reply: Sputters, loss of power and burning smell?
