3.0 Starting Issues Possible Timing
Old 03-25-2014, 05:17 PM
  #51
jcman's Avatar
Ok this says it all unfortunately.
Old 03-25-2014, 05:20 PM
  #52
xdewaynex's Avatar
That made my eyes hurt reading that, lol. So the window on the flex plate does need to line up?
Old 03-25-2014, 05:26 PM
  #53
jcman's Avatar
I'm trying to pdf that page so you can read it or you can copy paste this one to your desktop to zoom it.
Old 03-25-2014, 05:35 PM
  #54
jcman's Avatar
Here it is
File Type: pdf
Old 03-25-2014, 05:49 PM
  #55
xdewaynex's Avatar
Thanks for that. Definitely worth checking out if its misaligned. After all this searching, its weird today is the first day Ive come across this.
Old 03-25-2014, 05:54 PM
  #56
jcman's Avatar
Hey no problem, well that just plain out sucks in my book.
So then the procedure should be to put the crank locking pin in and position the flywheel gap at the sensor's position.
Old 03-25-2014, 05:57 PM
  #57
jcman's Avatar
Here is that one if it helps.
Good Luck!
File Type: pdf
Old 04-18-2014, 07:30 AM
  #58
xdewaynex's Avatar
Well I finally got time to get the motor and trans out, separate the 2 and found that the flex plate was 180* out. My problem now is that I thought the window of the flex plate would line up with the crank sensor straight up, but in order to bolt it up, its either above the sensor or below. Would you happen to know where exactly it needs to be?
Old 04-18-2014, 09:53 AM
  #59
jcman's Avatar
Use a crank lock bolt and take a look, I'm sure that would be the only logical way of knowing were dead center #1 is because you really can't go on the damper timing marks.
Old 04-18-2014, 10:16 AM
  #60
xdewaynex's Avatar
I should have mentioned the crank lock pin is in place. I removed the cylinder 3 spark plug, inserted a long extension and watched it raise up as I rotated the crank. Watch for the timing mark on the dampener and looked for the hole in the crank for the pin and everything is lined up.
Here are 2 picks of kind of whats going on at the moment.
Here you can kind of see the window on the flex plate sitting right above the dowel for the trans...
Here it is from a side view.
Now if I were to remove the bolts and rotate the plate counter clockwise to where the bolt holes realign, the window would be below the crank sensor.
My dad was saying to him it seems it sitting right above the dowel would be fine, as when you try to crank, it would move right past the crank sensor as soon as you cranked it.
Quick Reply: 3.0 Starting Issues Possible Timing
