CRAP! Camshaft moved?! Possible to figure out TDC again?!
Old 02-12-2014, 04:30 PM
  #81
acarney's Avatar
Originally Posted by SloopJohnB@mac.com
Just google the p/n.
I got a set fer shizzle. Or make your own with a couple of long metric bolts and pieces of pipe to go over them….or let it hang a little on the bolts alone.
I'm a little worried about accidentally putting too much weight on it and bending those bolts. I've actually already got one that's vent a little and was a pain to get back in; would only go in one specific mounting position. Was kinda wondering if anyone knew the size or part number of those bolts anyway.
Also, I don't have a part number for the support bolts, beside the 4 digit Audi special tool like (like 4077 or something, totally not that number tho) and googling that surprisingly isn't bringing back much... What does come back is just rental kits :-/
Old 06-24-2016, 07:28 PM
  #82
Alex2.7T's Avatar
Originally Posted by 4Driver4
This is minor. Cams moving a few degrees is common due to forces exerted by the valve springs. You have to set cam timing at the end anyway.
Don't sweat it. Use the locking bar to rotate the cam back into alignment. Easy.
this same happened to me, to which direction should sprockets be rotated clockwise or conterclockwise?
irelandbuyer
07-21-2019 01:54 PM
BriGuy01-2.7T
37
10-22-2015 08:04 AM
underextended
09-12-2015 11:37 AM
Zumkopf
09-10-2015 05:23 AM
Optimusglen
09-08-2015 06:57 AM
Quick Reply: CRAP! Camshaft moved?! Possible to figure out TDC again?!
