Forge 007 springs
Forge 007 springs
What are the signs or symptoms for running a diverter valve like the Forge 007 with a spring pressure that is too low or to high?
Say standard spring 5-15psi, but actual boost is 25 psi?
Potentially, the DV valve closing force (spring force plus boost pressure times piston area at vac line connection)
could be LESS than
force from boost pressure times piston area at the line from high pressure side)?
could be LESS than
MaD MaTTer
TT (Mk1) Discussion
05-18-2006 04:20 PM
back2black
29
04-23-2003 09:12 AM
