Has my car been abused?
So I just took delivery of a new 2014 a6 with a couple of hundred miles on the clock already. Does Audi have a way to check the car computer to see if this car was redlined during these few critical break-in miles?
Several possibilities for the 200 miles; it might have been used for a short period of time as a demonstrator, a loaner or used by a manager. It could also have been driven from another dealer and the customer changed his mind.
so it is technically possible to red line the engine and NOT have it picked up by a computer scan...(unless a fault is triggered). In this case...there is no fault....but the rotors appear warped (indication of hard driving). dealership is willing to check/scan...but it sounds like this may be a false negative.
While anything is possible, it seems doubtful 200 miles of hard driving would warp new factory rotors that quickly.
If your brakes are pulsating, have the shop clean up the rotors with a wire wheel. Turning them down in a lathe will do it too but it makes the rotor thinner which means you will be replacing them sooner. Better yet is to have them replace rotors and pads with new parts.
When I go to buy a car, I find one in the color I do not want and then test it for performance, braking, handling etc. I then drive the one I want to buy and drive it carefully knowing that it needs to be cared for during its break in period so it is possible that with 200 miles it has been hammered by people with my buying technique.
The ECU will log the event of speeding and redlining. this logging is only to be seen by dealers/insurance when there is an event of so called blowing the motor when the owner claims "the engine just blew up"
I did not drive mine really hard until I had the first oil change out of the way at 5000 miles. That first oil degreases, allows for seating and suspends the particulates that are most apparent in a newly assembled motor. After the first change I felt good to go for it!
