S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
new to the s4 world (whys my eng vibrating)
Old 03-25-2014, 02:12 PM
Genduso's Avatar
Originally Posted by Jimi62
I have owned My S4 for 8 years now and I have had my share of problems... Does the Car Vibrate when you are idling or do you have to be moving to experience this?
If it is vibrating when you are at idle you can just look at the engoine and see if you have excessive movement? If you have to be moving then it might could be Wheels, tires suspension???
Also Is it Speed related.
Thanks for tring to help me jimi. u can feel it a little at idle. vibrations are more severe over 2k rpms. driving or stopped. still no cel. it is a on/off symptom. mounts looked good no leaks. im hoping its not the flywheel. any other suggestions? its going to the dealer sat.
Old 03-26-2014, 07:42 AM
DOALLAR's Avatar
Genduso, awhile back I read a post (on another european car forum) with a gent whom experienced the same type of symptoms. Turn out to be the fly wheel was the culprit. Let us know what you find out.
Old 03-26-2014, 09:47 AM
Genduso's Avatar
Yeah its seems to be the flywheel from what ive been hearing. sucks. I have a used flywheel here at work from a 04 b6 s4. Seems in good shape. Any problems fitting in my B7?
Old 04-23-2014, 10:06 AM
Genduso's Avatar
ok now the vibration happens all the time now. when u press on the clutch u can hear the flywheel making noise. Sucks. Bought new luk flywheel & clutch kit from parts geek. $840 w/ free shiping. not to bad.
Now i have to figure why my clutch pedal in my gti is all the way to the floor. Got to drive it for a bit now. hoping a bleed will fix.
Old 04-24-2014, 06:58 AM
DOALLAR's Avatar
B6 flywheel install on B7 - is ok. See here;
http://www.audizine.com/forum/showth...-ready-to-ship
Gti - Check the master slave cylinder container for loss of fluid or like you said a bleed could do the trick (there may be air in system). Hopefully you will not have to replace the master slave cylinder.
r171amg
45
10-25-2020 07:04 AM
thenail01
03-15-2010 07:35 AM
rippleAdder
10-12-2009 01:48 PM
wolv1414
27
05-10-2004 04:29 PM
Quick Reply: new to the s4 world (whys my eng vibrating)
