04 A8 Bluetooth retrofit
Old 10-03-2013, 08:18 PM
  #21
mishar's Avatar
Originally Posted by 2k4blacka8
Well I understand your logic but here's the thing, I've read plenty of threads if I retrofitted the OEM unit, I would either have to plug the MOST from the CD Changer or the XM unit and I would like to keep those. I don't know where else I can plug in the MOST in at. Since I want to keep both of those units, that's why I might consider going with the cradle. I'm still deciding on what to do.
Didn't I explain to you how to connect it and keep all modules you have?
Old 10-03-2013, 08:27 PM
  #22
2k6blacka8's Avatar
Originally Posted by dvs_dave
Here ya go...
http://www.fiscon-mobile.eu/products/pro_mmi_lwl.php
Practically OEM quality
Will this plug into the console where the cradle plugs into??
Old 10-03-2013, 08:31 PM
  #23
2k6blacka8's Avatar
Well you told me how it's hooked up and what's needed but not how to keep the XM and CD changer especially me having the Pre 05. Like I said I don't know where else to tap in the MOST. Is there an adapter I can get or something??
Old 10-04-2013, 12:03 AM
  #24
mishar's Avatar
I told you that you need two fiber optics harnesses and enough fiber optics to the CD Changer and back to the Bluetooth so you can make it part of the Ring without loosing any module you already have.
Edit: Actually three harnesses. One female and two male.
Old 10-04-2013, 04:29 AM
  #25
2k6blacka8's Avatar
Ok I kinda get it now. Do you have any pics of what they look like?? How much does the dealer charge for those 3 harnesses???
Old 10-04-2013, 06:39 AM
  #26
AudiWorld Wiseguy
dvs_dave's Avatar
No, it's typically installed in/behind the glovebox. It needs to connect into the MOST fiber ring, and also be powered. It comes with the appropriate connectors to allow you to do this by daisy chaining off the CD changer power and MOST connections.
The Mic needs to be installed in the roof console, but you might be able to trace the existing but useless wiring from the OnStar mic and use that instead. Although I'm not sure down which A-pillar those wires are run?
The cradle option allows only voice over the speakers and call answer/end/voicedial from the steering wheel button. Nothing else. It has zero integration with the MMI system. Hence my "old tech" comment.
Old 10-04-2013, 08:15 AM
  #27
mishar's Avatar
It is same configuration as for retrofitting AMI. Just longer fiber optics.
Old 10-04-2013, 08:56 AM
  #28
05SilverA8's Avatar
I should have a few of the 5M fiber optic cables with connectors and ringbreak wire bundled for about $75 or so in about 2 weeks. I ordered some and will be having them finished up by a local cable shop. This is by far the easiest way to do the BT upgrade, just run the fiber optic wire to the trunk.
Old 10-04-2013, 07:15 PM
  #29
2k6blacka8's Avatar
Well I was planning on running the module where the telematics used to be. I'm not worried about it being a flood place but at least it will be easier to hook up. I don't want to run any wires to the trunk. The only thing I want to run is the most wire. That's it. What does this ringbreak harness look like??
Old 10-05-2013, 06:41 AM
  #30
05SilverA8's Avatar
It is the MOST fiber optics with a RingBreak wire. You just run it to the trunk, splice into the amplifier with supplied splice (just take apart fiber connector and put one fiber in splice connector). You then locate RingBreak wire from Amp and use a connector to tap into it to bring this to the unit under the carpet. Power, ground, Mic+ and MIC- are available from old Telematics unit under carpet. If you want I can have power wires added to wire bundle to take power from trunk, but no need. MOST fibers were ordered from overseas the other day, should be available within 1-2 weeks.
Quick Reply: 04 A8 Bluetooth retrofit
