What is the largest SD card the MMI-3G+ system will acknowledge?
Old 04-24-2013, 03:10 AM
iconoclast's Avatar
Default What is the largest SD card the MMI-3G+ system will acknowledge?
If I recall correctly it used to be 2GB on the previous generations. Is that still the limit or has it been raised?
Old 04-24-2013, 08:06 AM
dingo_s4's Avatar
I have two 32gb cards in mine - they work great. They have to be formatted FAT32, as 32gb is the normal upper limit for FAT32. I tried a 64gb card and it worked - you have to use a work-around to format the larger size. The 64s worked but were REALLY slow to mount to the system. Instead I run a 500gb hard drive in the glove box.
Old 04-24-2013, 09:30 AM
iconoclast's Avatar
excellent. thank you.
Old 04-24-2013, 03:50 PM
joeg829's Avatar
How did you add the hard drive.
Old 04-25-2013, 11:17 AM
dingo_s4's Avatar
Dealer part number 4F0-051-510-H - its a mini USB adapter that plugs straight into the hookup in the glovebox. It will show up on the "Media" meu when it's on.
ltooz_a6_a8_q7
Q7 MK 1 Discussion
09-05-2017 10:31 AM
ltooz_a6_a8_q7
09-05-2017 10:29 AM
vtmikevt
S4 (B8 Platform) Discussion
05-04-2011 08:56 AM
muski
10-03-2008 04:10 PM
Quick Reply: What is the largest SD card the MMI-3G+ system will acknowledge?
