Code P3081
Old 11-09-2009, 07:00 PM
  #21
emjayem's Avatar
Originally Posted by janserce79
Aaaa one more thing I forgot! Do you know how much coolant will I loose after removing G62? I don't think it will be alot cause the sensor is pretty high...And yes I know to do it on the cold engine! :-)
you know, I have had some lose a quart or so and I've had some lose absolutely none! I would pick up a liter or 2 to be safe, you can always return it! Good luck on the fix
Old 11-22-2009, 05:38 PM
  #22
janserce79's Avatar
Thanks! So I changed the sensor today. It was easy and had no problems. I lost about 1.5 Qts of coolant. Then erased the code, check engine went off, coolant temp gauge came back to normal and finally stayed there!:-)
Emjayem thanks for great help and patience!
Old 11-23-2009, 05:51 PM
  #23
emjayem's Avatar
Hey no problem, happy to help. Glad it all worked out for you!
Old 06-22-2010, 09:54 AM
  #24
Keithr726's Avatar
Where can I get this sensor and whats the part number? I have the same problem with p3081, just did TB and thermostat and that didn't help.
Old 10-02-2010, 09:59 PM
  #25
PDXA4's Avatar
Rather basic question, but is it possible to suck up a sufficient amount of coolant from the reservoir so that the level would be lower than the sensor in order to replace it without having coolant gushing out ?
I have the same sensor issue right now and would like to change it out, just worried about the mess from the coolant...Any other tips would be appreciated, tks...
eggsngrits
12-08-2021 06:58 PM
brandonb93
A4 (B7 Platform) Discussion
12
12-04-2018 01:16 PM
mxp
09-26-2015 10:15 AM
ECS Tuning-Audi
09-25-2015 08:20 AM
mdkv5
A6 (C7 Platform) Discussion
09-16-2015 01:09 AM
Quick Reply: Code P3081
