Air Spring DIY
Old 09-09-2011, 03:10 PM
  #31
jay956's Avatar
Originally Posted by Kneale Brownson
I found when replacing axles that using a big rubber hammer to pop out the upper control arms worked pretty well. I also found that if I did the rear one first, it came out easier than if I took out the front one and then struggled with the added pressure on the rear one.
well after a lot of cursing, hammering, lubing, cursing some more, and having the apartment manager mad at me (not supposed to work on cars in the parking lot), the rear came out. didnt have time to finish, had to go to work. will go back to it tomorrow.
Old 09-10-2011, 05:41 AM
  #32
Kneale Brownson's Avatar
I had to put pressure on the strut assembly in different directions until I found which relieved the pressure on the control arm the most to allow both removal/reinstallation. So I was pushing with one arm, using the rubber hammer with the other.
Worked a lot better when installing to put the rear back in first too. I used lots of antiseize on both the joint and the pinch bolt.
Gotta go do this again soon to replace the airbags.
Old 09-10-2011, 08:27 AM
  #33
jay956's Avatar
got the old assembly out this morning, only to find that the bolts are not torx bolts like i have been reading. napa down the street actually has some triple square bits in stock, gonna go there after work. hopefully i can finish this up today and this job wont go into the third day.
Old 02-09-2014, 09:26 AM
  #34
barny0055's Avatar
what happened to the pictures for this diy? I am trying to figure this out but I cannot find any pics.
New link to article and pics
https://www.audiworld.com/tech/wheel57.shtml
Old 04-14-2014, 06:34 PM
  #35
rosco_nz's Avatar
Originally Posted by ryry
Could simply replacing the o-rings possibly fix a leaking air spring? My front driver side is leaking and I am looking for a temporary fix until I can get my coilovers on.
Yes, I am sure my airbags were lot leaking at all, rather just the large O-rings at the top .. the triple square bolts at the top are supposed to be torgued to 23NM to squash the rubber mount at the top .. they were finger tight only. There was also visible evidence of leaking airflow in the alloy casting ..
Suggest you check this deal before committing to new springs.
Old 08-16-2019, 06:13 PM
  #36
inchung Lee's Avatar
Default Wow iit is what i look forward but can i fix or replace the rubber sleeve in airsprin
Thankyou fie inform.
Can i repalce rubber sleeve in air spring???
rockyallroadiguy
Audi allroad
02-21-2019 06:38 AM
rockyaudi
Audi allroad
01-06-2014 12:22 PM
paulouk
Audi allroad
09-25-2011 12:39 PM
jibmaster1
Audi allroad
07-23-2008 07:34 PM
Quick Reply: Air Spring DIY
