Audi Q5 Subwoofer swap
Hello,
I have a 2012 Q5 S Line. I have the B&O Sounds system and was wondering it I can get a subwoofer with a little more bass in there without messing around to much.
http://www.crutchfield.ca/jl_audio_6.../1366w3v38.htm
Would this subwoofer work? Are the ohms (8 or 4 ohms?) and wattage correct? What about the depth for where it is currently mounted? Would it sound proper?
Its easy enough to swap them out, just dont wanna screw the system up.
Thoughts???
Thoughts???
it looks like it might fit just fine.
My DF is the Q5's primary driver, it I drove it more then once a week I'd change the sub...
Hello,
I would like to wire in a new subwoofer and amp.
I would like to take the feed from the low level input prior to it entering the factory amp.
The amp is located in the boot side panel.
I also need the 12v remote wire.
Can anyone tell me the wire colours I need for the above or better still a wiring diagram??
Many thanks mark.
Many thanks mark.
Hello,
Many thanks mark.
Many thanks mark.
Attachment is in PDF form
What if I don't want change
It lets u lower bass and up sub like a equalizer in the settings. What would b the best setup for the stock music system i tried messing around but now it sounds dumb I tried to put every setting back to what it was but i can't remember than everything half way and that sounds weird like weak
Replacing the sub without upgrading the power will only yield minimal improvement and IMO is a waste of time and money. Do it right and get a custom enclosure with a proper amp. JL Stealthbox is a great solution for many cars, unfortunately they don't make anything for Audi.
BGEDWN
03-01-2007 11:53 PM
