View Poll Results: Do you prefer the OLD FAQ?
I want the OLD FAQ back!
100.00%
I like the NEW FORMAT
0%
Voters: 4. You may not vote on this poll
AUDI A4 | B5 | 8D 1996 - 2001 FAQ Frequently Asked Questions and Common Problems Thread Collection
Old 05-17-2006, 02:03 PM
  #451
Jon-1.8t's Avatar
Default A few tips / tricks
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2535197.phtml">https://forums.audiworld.com/a4/msgs/2535197.phtml</a</li></ul>
Jon-1.8t is offline
Old 05-24-2006, 09:21 AM
  #452
Andy_FL's Avatar
-= RECALL [JE CAMPAIGN] HAS EXPIRED =-
Andy_FL is offline
Old 06-01-2006, 08:50 PM
  #453
SpeedyDTP247 CQ+UrS4's Avatar
Default Tire Size Calculator
<ul><li><a href="http://www.miata.net/garage/tirecalc.html">Tire Size Calculator</a></li></ul>
SpeedyDTP247 CQ+UrS4 is offline
Old 06-16-2006, 07:21 PM
  #454
Default Supercharged 12v 2.8
pics courtesy of Fast28 (more info can be found in the two links below)
<img src="http://www.audifans.net/modules/Gallery/albums/album63/DSC00011.sized.jpg">
<img src="http://www.audifans.net/modules/Gallery/albums/album63/DSC00012.sized.jpg">
<a href="http://www.audifans.net/modules.php?name=Forums&file=viewtopic&t=8506&post days=0&postorder=asc&start=0">Supercharged 12v 2.8 (from audifans.net)</a>
<a href="http://scaudi.com/sc/index.php?showtopic=2777">scaudi.com post of the 12v s/c</a>
Old 06-27-2006, 01:53 PM
  #455
BSK
BSK's Avatar
Default S4 | RS4 on B5 platform DIY Thread
<ul><li><a href="https://forums.audiworld.com/s4/msgs/1484364.phtml">https://forums.audiworld.com/s4/msgs/1484364.phtml</a</li></ul>
BSK is offline
Old 06-27-2006, 01:54 PM
  #456
BSK
BSK's Avatar
Default B5 S4 FAQ by Edy Jun
<ul><li><a href="http://homepage.mac.com/edyjun1/S4/index.htm">http://homepage.mac.com/edyjun1/S4/index.htm</a</li></ul>
BSK is offline
Old 06-27-2006, 05:39 PM
  #457
Jon-1.8t's Avatar
Default GT 28RS Stainless Steel Line Turbo Feed and Drain Line Lengths
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2568869.phtml">https://forums.audiworld.com/a4/msgs/2568869.phtml</a</li></ul>
Jon-1.8t is offline
Old 06-29-2006, 11:33 AM
  #458
Ash A4's Avatar
Default 35% all around
<center><img src="http://pictureposter.audiworld.com/95012/ashs_tint.jpg"></center><p>
Ebony Pearl Effect
Ecru interior
Johnson Film - Silhouette 35% all around
Ash A4 is offline
Old 07-06-2006, 10:15 AM
  #459
JettaRedII's Avatar
Default A4 Bentley Manual Online--Alternative (wiki)
Here is a fee based online manual that is essentially a Bentley.<ul><li><a href="http://www.alldatadiy.com">On-line Manual</a></li></ul>
JettaRedII is offline
Old 07-06-2006, 05:49 PM
  #460
A4SilverT's Avatar
Default B5 Spring Heights, OEM Non-Sport, Sport, and Aftermarket
A popular suspension modification is replacing the stock springs and shocks. Sometimes this is done to get better handling performance, sometimes just to lower the vehicle, and sometimes to do both. But often it's unclear what the data and specifications in the ads really mean.
The B5 came with a standard suspension that produced a ground clearance of 4.3 inches. An optional sport suspension was available with shocks and springs designed for better handling at the expense of a softer ride. The sport suspension lowered the vehicle by .75 inches (actually 20mm), giving it a ground clearance of about 3.5 inches.
Popular aftermarket springs lower the vehicle even more than the sport suspension. However, the lowering numbers listed in the ads for them are almost always based on the stock non-sport height. Here's the data for the commonly used springs:
H&amp;R Sport Springs lower the car 1.25" in the front and 1" in the rear from the stock non-sport height or .5" in the front and .25" in the rear from the stock sport height.
H&amp;R Race Springs lower the car 1.9" in the front and 1.5" in the rear from the stock non-sport height or 1.15" in the front and .75" in the rear from the stock sport height.
Vogtland Sport Springs lower the car 1.5" from stock non-sport height and .75" from stock sport height.
Vogtland Club Spec Springs lower the car 1.4" from stock non-sport height and .65" from stock sport height.
Eibach Pro-Kit Springs lower the car 1.4" in the front and 1.3" in the rear from the stock non-sport height or .65" in the front and .55" in the rear from the stock sport height.
<b>WARNING: These numbers apply only to quattro AWD B5s. Numbers for 2001.5 MY B5s may differ because of the redesigned spring perches. Check with the manufacturer or your vendor to confirm.</b>
The problem with lowering the vehicle is that the resulting reduced ground clearance may result in increased damage to the vehicle undercarriage due to debris on the road. Only the stock non-sport suspension, for example, can be counted on to get the vehicle safely over a 2x4 laying on end. Another problem with a lower vehicle is a reduced approach angle which may cause the front of the vehicle to scrape on driveways, speed bumps, etc. (or the rear of the vehicle if going backwards). You'll also risk bottoming out sooner in deep snow. Before you lower the vehicle, think about how this will impact your driving and repairs.
If you want performance without significant lowering, you have two choices. You can install coilovers in place of the shock/spring combination. Many coilovers are height adjustable. You can also install a performance shock with your OEM springs, sport or non-sport.
_____
A4SilverT is offline
Quick Reply: AUDI A4 | B5 | 8D 1996 - 2001 FAQ Frequently Asked Questions and Common Problems Thread Collection
