Q5 separate Fan operation for driver and passenger
Old 04-20-2014, 04:35 AM
pbmaverick's Avatar
Default Q5 separate Fan operation for driver and passenger
I am trying to adjust the fan to separate settings for driver and passenger but it continues to adjust both at the same time??? any suggtions. Thanks
Old 04-20-2014, 05:24 AM
jack-e-son's Avatar
Press the fan and adjust the passenger side then adjust the driver. The driver would be the master and control both regardless. Once you change it on the passenger side, the sync is broken
Old 04-20-2014, 07:54 AM
spijun's Avatar
You can only change the temperature but not the fan speed.
Reason: exists only one motor for fan
Old 04-20-2014, 08:07 AM
btlalum's Avatar
Default Fan
I think there's only one "fresh air blower" (as Audi refers to it) so separate control driver/passenger really isn't possible. If you mean the temperature setting, do as jack-e-son said and change the passenger side and it will break the synch.
Old 04-21-2014, 02:34 PM
jack-e-son's Avatar
yeah.. i just tried it.. only one blower setting for both sides
Old 04-22-2014, 10:43 AM
userbbc's Avatar
I think they might have removed this feature after the first round of interior changes on the b8. I remember my 2009 B8 A4 having two fan adjustment buttons - one for driver, one for passenger. The 2013 Q5 I have now only has one fan adjustment button.
At the same time, they did away with the 6 way adjustable heated seat adjustment from the climate control console to a single button with only three settings.
Old 04-22-2014, 11:28 AM
spijun's Avatar
True to MY2009-2012, for A4,A5, Q5 there are two fan adjustment buttons - one for the driver, one for passenger but the function is the same.
You do not have different speed fan possibilities because only one blower
Old 04-22-2014, 12:05 PM
userbbc's Avatar
wow, never actually tried it the three years I had the A4 but nice to know we had dummy buttons in the earlier models.
Old 04-22-2014, 12:52 PM
spijun's Avatar
You did not read Owner's Manual
Audinewbi
Q5/SQ5 MKI (8R) Discussion
19
01-23-2012 12:29 PM
BikerBill
01-07-2008 07:08 PM
00zero
Audi Original "S" Cars
06-13-2004 04:57 PM
beep-beep
Audi 100 / A6 (C4 Platform)
07-23-2003 08:56 PM
Via911
TT (Mk1) Discussion
14
04-09-2001 06:36 PM
Quick Reply: Q5 separate Fan operation for driver and passenger
