Biodiesel - still an issue?
Old 02-19-2014, 03:04 PM
Turguin's Avatar
Default Biodiesel - still an issue?
We're trading in our Q5 hybrid for a Q5 TDI and there are some places near us that sell biodiesel. There seems to be some bias against biodiesel and I can't quite figure out why.
Posts in this forum mention that if you use above a 10% biodiesel mixture, you should get the oil changed more often. Why? I ask because some places near me sell 99% biodiesel! I've read recommendations that say during cold months you should do a 25/75 split. There appears to be a wide gap between what's available and what's recommended, allowed or considered harmful for your car.
Can anyone help me cut through all the messaging?
TIA...
Old 02-20-2014, 03:31 AM
TornadoRed's Avatar
It depends on the design of the diesel particulate filter (DPF). Some TDIs have a system which supplies raw fuel to the DPF during the regeneration phase by passing it through the combustion chamber. When this happens, uncombusted fuel can be scraped off the cylinder walls by the rings and pulled down into the oil sump.
Someone else can speak up regarding the Q5's DPF technology; it may not use the described method, so may not be prone to fuel contamination. But the owner's manual should specify what limits are placed on the biodiesel concentration.
A low biodiesel concentration, for instance B02 or B05, is beneficial as it provides lubrication to the moving parts in the injection system. B10 may still be okay -- let's hope so, since in some states that's all that's available. But owners of TDIs with a DPF should probably avoid biodiesel blends greater than 10% (B10). In a pinch, of course, any biodiesel blend can be used, as long as it's high-quality fuel meeting the relevant standards.
Old 02-22-2014, 05:44 PM
Turguin's Avatar
Thanks for the information. Good stuff to consider.
chubs636
TT (Mk1) Discussion
09-14-2015 03:42 PM
Delsol67inamsterdam
Audi A3 / S3 / RS 3 MKII
09-13-2015 09:18 PM
cbpdpm
S6 (C7 Platform) Discussion
09-12-2015 10:02 AM
RTnDL
09-07-2015 11:17 AM
sethm1
Audi A3 / S3 / RS 3
09-04-2015 04:01 PM
Quick Reply: Biodiesel - still an issue?
