Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
MMI locked up on the loaner car for a while (long)
Old 11-15-2007, 10:43 AM
crespo's Avatar
Default MMI locked up on the loaner car for a while (long)
Sequence of events:
MMI was fine on my drive home from work. I turned the car off, and MMI turned off as well, everythign was fine. My sister and a friend took a drive in it, came back and said they couldn't get the radio to work. I take a look, and notice the clock was stuck at 12:00AM, no sound was coming out at all, the track progress for the CD wasn't moving (no AMI) stuck at 1:23, switching radio stations wouldn't work, and it wouldn't shut off completely if you tried to turn it off. A friend and I went and drove it for a while, all the while MMI would remain inaudible/unplayable. You could switch between the modes, and change the fade, balance, etc levels, but it just wouldn't play anything out of the speakers. Clock still stuck at 12:00AM (the driver information screen's clock read the proper time the whole time, obvious lack of communication between the two).
We come back home, I turn the car off, but notice MMI stays on. I was outside the car and noticed the MMI screen wouldn't get off of the "Audi MMI whatever" intro screen when it boots up. I was standing outside the car, and had to run back into the car to pick up a call on my mobile because it was still connected via Bluetooth!!
I drive a bit more, come back, turn the ignition off, stand outside the car for a few minutes and notice the MMI screen had finally turned off. Knowing the battery was no longer at risk of running out of juice overnight, I go to bed, come back in the morning and everything's fine.
Guess that's what happens when your driving the 87th car off the assembly line... I hope those gremlins are all figured out by the time my own car comes in.
MMI manual was in German, btw...
(bad) pictures for your time
<img src="http://pictureposter.audiworld.com/83697/drl.jpg">
<img src="http://pictureposter.audiworld.com/83697/drl2.jpg">
(yes, S8)
Old 11-15-2007, 11:23 AM
Tal-Yvan's Avatar
Default I could easily blame the Bluetooth syncro monkey...
Basically because it's the only external device that is scanning.
I've seen similar situations in laptops.
Old 11-15-2007, 12:42 PM
acadia1's Avatar
Is there a reset button? There has to be.
Old 11-15-2007, 04:45 PM
sjenner's Avatar
Default wow that sux
I guess the germans need to take lessons on quality control for electronics from the Japanese. Audi and BMW make great engineering but lousy electronics!!!
Old 11-15-2007, 07:32 PM
antiSUV's Avatar
Default Found this on the C6 forum. Hope this helps!
<ul><li><a href="https://forums.audiworld.com/c6a6/msgs/40237.phtml">click here</a></li></ul>
Old 11-15-2007, 08:11 PM
Roswell's Avatar
Re: did your sister confuse it? They say 90% of audi buyers are male.
Old 11-15-2007, 08:13 PM
Roswell's Avatar
Re: press and hold opposite corners I think.
Old 11-16-2007, 04:16 AM
crespo's Avatar
it's fixed now (and back at the dealer), but that's good info for the future.
Old 11-16-2007, 10:46 AM
Levent's Avatar
crespo, where is your all the A5-S5 colors post?
Old 11-16-2007, 01:21 PM
crespo's Avatar
Default my university server finally got taken down, but they're all on brymci's picasa album
<a href="http://picasaweb.google.com/brymci/A5Collection3/photo#5120115569241449746">link</a>
Quick Reply: MMI locked up on the loaner car for a while (long)
