Very aggrivating leak...
Old 01-28-2014, 12:09 PM
Prospeeder's Avatar
Originally Posted by josefprem
You you have a link for the cam seals? I have the leak on the driver side by the firewall so the tensioner is on the other side at the front, but there is still a seal on the side I have a leak correct? (non tensioner side).
Do I need to remove the cam? Doubtful I am guessing.
Thanks
That would be the Cam bore plug leaking. You need to replace Valve covers,chain tensioner gaskets and the rear cam plugs or you will be wasting your time doing this over and over.
Old 02-03-2014, 09:04 AM
josefprem's Avatar
Thanks very much for the info. That is what I was fearing. Guess I need to get the
Cam tensioner tool to get to the seal under. Is it easy to remove and replace the cam plugs?
Old 02-03-2014, 06:38 PM
Prospeeder's Avatar
Yes remove the bearing cap over them and pull them out and replace.
marvgomez
02-06-2009 02:31 PM
wonder1and
13
03-18-2008 12:38 PM
S4AVT
09-03-2005 04:31 PM
Cole 2.8Q
02-25-2005 06:44 AM
MelloYelloS4:Indkted
TT (Mk1) Discussion
01-09-2005 10:29 AM
Quick Reply: Very aggrivating leak...
