2001 A6 2.7t error codes need help
Old 09-14-2013, 09:52 AM
oakland8124's Avatar
Default 2001 A6 2.7t error codes need help
Have error codes-
1) p1114
2) p1423
3) p1411
And Engine codes-
1) 17526
2) 17522
3) 175861
Any help would be great
Old 09-15-2013, 05:27 AM
georgeb944's Avatar
http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
Old 09-16-2013, 12:55 PM
I have looked these codes up. I'm wondering if its because of a vaccum leak, bad o2, bad egt sensor?
Old 09-16-2013, 01:08 PM
georgeb944's Avatar
Each code represents a different failure in the motor management system.
If the code is for a bad O2 sensor, then replacing the sensor is probably the fix for this. If it is for a vacuum leak, then fixing the vacuum leak will probably fix the code.
Old 02-22-2014, 01:53 PM
VAVAMATT's Avatar
I am wondering what can cause my obd2 not to work, i used a diagnostic tool and it doesnt connect... What can it be? I have 2001 audi a6 quattro 2.7t awd...i would like to see the codes but cant go through!
lmvaudi
07-10-2013 12:07 PM
Wilket
VAG-COM Discussion
12-21-2010 04:42 AM
gb944
VAG-COM Discussion
04-20-2005 07:01 AM
RWLib3
VAG-COM Discussion
08-17-2004 08:00 AM
Frank C
VAG-COM Discussion
01-24-2004 04:47 AM
Quick Reply: 2001 A6 2.7t error codes need help
