Trouble installing Parrot CK3100 into 2000 Audi TT
Old 01-14-2006, 06:39 AM
digitaltrader's Avatar
Default Re: This is what the back of my headunit looked like
I had a person tell me that I couldn't use the line- and line+ (brown and green wires) as the radio requires a high level input which those two are not. However I see you successfully used them. Any ideas who is correct? Ill try and see.
Old 01-14-2006, 06:43 AM
Default Re: If it's a Bose system...
How do I know if I have a bose system? I have bose speakers but am not sure if that means its a bose system. And TT-Nuge says he didnt need to do that in his, so do you have a non-bose system. I am getting confused.
Why can't I connect to the audio tel- tel+ and mute in a bose system?
Old 01-14-2006, 06:49 AM
Senior Member
TT_Nuge's Avatar
Default Well if my way is wrong it sounds like it works better than the right way.
I'm not an electrical genius, far from it. But I did this with the help of the single post I linked and that picture from Jeff Bipes. I have the CK3100 and the BOSE Concert II headunit in an 02 Coupe. I hooked up 6 wires total and no harnesses, 3 wires to the back of the headunit in the telefon box and then the 2 power/1ground to spots under the steering column. Worked great the first time and every time.
Trent
Old 01-14-2006, 08:18 AM
msauve's Avatar
Default So, on your Motorola...
do you have any contacts with multiple numbers (home, work, mobile, etc)? How do those appear in the Parrot address book? They're _supposed_ to appear under a single name, with individual numbers labelled appropriately.
Old 01-14-2006, 08:20 AM
Senior Member
TT_Nuge's Avatar
Default I don't have contacts with multiple numbers
Old habit I guess but each person's number has a seperate entry in my phone. Always done it that way.
dav2321
TT (Mk2) Discussion
10-27-2010 07:04 AM
digitaltrader
TT (Mk1) Discussion
01-23-2006 02:55 PM
frnk
TT (Mk1) Discussion
24
01-10-2006 01:40 PM
BoostedAudi
02-10-2004 11:02 AM
mshan
12-12-1998 12:30 PM
Quick Reply: Trouble installing Parrot CK3100 into 2000 Audi TT
