Old 07-25-2016, 10:01 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi Q5 or Q7 Exterior Guides
Print Wikipost
Anyone towing with their Q5?
Old 09-20-2011, 12:08 PM
allgrrl's Avatar
My brake is mechanical so no controller required. Best way to go in my opinion/situaiton.
Old 09-20-2011, 05:25 PM
Jusforfun's Avatar
You guys even notice thats a V6 3.0 TDI Q5 in the pic? 500mn torque thats no pony.
Old 09-20-2011, 07:20 PM
OlyS4's Avatar
Originally Posted by allgrrl
I'm towing a 1300 pound camping trailer and it is fine. Drops gas mileage somewhat but not terrible. At 4400 rating I'd not want to tow more than 2200 which is half. From Seattle most directions involve mountains and I want plenty of wiggle room. This is a 2.0 and you don't even know the trailer is there. The big mirrors are great, too.
allgrrl in Seattle
Hey, I'm in Oly and agree, lots of "hills" and mountains! I'll most likely be going with a 3.2, and am wondering if towing a 3000lb 18ft ski boat and trailer over to Chelan would be possible? Not on a regular basis, maybe once a year when we want to actually experience sunshine, mostly just shorter trips to lakes or the sound which I have no doubt it could handle. I'm thinking an OEM hitch and a trailer with surge brakes would most likely suffice with the weight I'll be towing.
Old 09-21-2011, 03:50 AM
CrustyNoodle's Avatar
Originally Posted by 1atlas
That has to be at 4400lbs? How does the Q5 handle that load on start, stops and hills?
In the rest of the world, the Q5 is rated at a towing limit of 2400kg (5280 lb) with the correct tow hitch fitted (like the factory installed swivel hitch or appropriate after market hitch). My set up has the full 2400kg tow rating and I estimated this load at around 2000kg (4,400 lb) so not a problem there!
The trailer had surge brakes which as always are a little clunky but very effective. So braking was no trouble at all though as always you need to drive accordingly. I was more concerned about the Camry breaking loose than anything else.
With the factory fit, dealer fit (if done properly) and DIY fit (again if done properly), the trailer control module is fitted which interfaces with the car's electronics including the ESP which has a specific function to control trailer sway. I have the trailer control module all rigged up and I didn't experience any untoward trailer sway.
the whole set up tows like a champ!
Originally Posted by OlyS4
Thanks for the info. After searching the forum, it seems like the Audi hitch is a little less expensive to install when you have the S-line due to the "trap door" already on the S bumper cover, which is great because I'm looking at the S-line anyway.
I can't seem to find any definitive info on the the EBC. Does the OEM hitch come as a package with the EBC, or is it not actually a controller but instead an interface? Sounds like it is integrated with the ECU because some of the posts indicated that it affects engine and tranny settings. Is it simply a module that plugs into a harness in the back, and then you buy a brake controller separately?
The trailer control module does not include electronic brake control. You'd need to fit this separately however the wiring plugs are already fitted under the dash to make this process easier - there are a few forum threads around from others who have done this.
Too right! No problem with take-offs or hills with this baby!
If you're going to be towing at altitude (or even if you're not) then I'd recommend the 2.0TFSI engine. It produces more torque at lower rev's than the 3.2FSI so would probably be better suited to towing. The difference at altitude would be even more pronounced with the 3.2FSI getting a little breathless (like us all).
Old 09-21-2011, 04:26 AM
JohnBoyToo's Avatar
You are correct - if towing is a priority, a turbo is the better choice for high altitude towing and a turbo diesel is even better
https://www.audiworld.com/forums/alb...albumid=164922
Old 02-19-2012, 06:42 AM
Cains10's Avatar
What exactly is required to tow with the Q5? Our Q5 has the factory tow package on the window sticker. From what I’ve read here, it appears that the Q5 has the hookup for lights, but not for electronic braking and the computer has the mapping for towing and the sway control. Is that correct? Would Audi service have the required accessories for brakes or would it be better to go to a trailer company for their professional assistance?
Old 02-21-2012, 02:35 AM
12 year Audi owner
StuffOfInterest's Avatar
The factory tow is what they call "tow preparation" which seems to imply just bolt holes and a tee in the wiring harness. I had a tow hitch installed on my 2012 Q5 and the total cost ended up being about $1600 for parts and labor. Actually cost more than the trailer I'm going to use it with.
One warning if you go this route, there is a removable plate in the back-bottom of the vehicle. The dealer took this plate out for the hitch and electrical plug to come through and then left the plate out when done. Interestingly, the plate has an outline on its back side to cut out for a proper fit around the tow hook. I'm still trying to get the dealer to finish the job and do that cutout as to me it looks very unfinished just having the entire plate out. If this doesn't resolve soon I'll have to get the Dremel out and do the cutting myself.
Old 02-21-2012, 11:41 AM
  #18
rick480's Avatar
Default Q5 towing
I tow somwhat regularily with my 2009 3.2. Installed the Audi hitch myself soon after I got the car. Very easy install.
I have towed a small 17' boat on several 300+ mile trips, a small utility trailer with misc stuff on board and a small Kubota tractor/front end loader 600 miles. Heaviest load has probably been 2000 lbs. No problems whatsoever with handling or acceleration. Gas mileage suffers a little but no more than wiht a stiff headwind.
I have used my Q5 to put a 26' 5000 lb boat in and out of the water with no problems but I only take it about 2 blocks, very slowly. Definitely looks like the tail wagging the dog. Pulls it right out even on a steep slippery ramp.
Old 02-21-2012, 01:42 PM
  #19
Stuttgartrob's Avatar
I rented a 2.0TDi a couple years ago to tow a car up to england to get tuned. A total of 24 hours of towing with it during th trip with no problems.
Old 02-22-2012, 01:30 AM
  #20
<a href="http://s63.photobucket.com/albums/h122/CrustyNoodle/Audi/?action=view&amp;current=IMG_1393.jpg" target="_blank"><img src="http://i63.photobucket.com/albums/h122/CrustyNoodle/Audi/IMG_1393.jpg" border="0" alt="Photobucket"></a>
Effortless...
Audi TDI POWER
Quick Reply: Anyone towing with their Q5?
