Old 07-22-2016, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Tire Repair and Maintenance
Print Wikipost
Audi Wheel Bolt. How much torque?
Old 09-15-2010, 05:17 PM
jeffry's Avatar
Thank you all for the information greatly appreciated!.
Old 11-20-2011, 12:01 AM
jasshrie's Avatar
Originally Posted by jeffry
Can so body please tell me how much torque I can give to the wheel bolt. I always check the wheels are tight. Thank You in advance...
Steel Wheels = 120 N-m
Alloy Wheels = typically 90 N-m
Old 11-20-2011, 07:17 PM
beep-beep's Avatar
on the same subject: does anyone uses anti-seize on the lug bolts?
Old 11-21-2011, 12:23 AM
jasshrie's Avatar
I have heard of people putting some around the seat between the bolt at wheel, but NEVER on the threads. I personally would never do it. If you don't over tighten, you should not have any issues.
BTW, to correct my previous post above, it appears that some Audi with Alloy wheels also recommend 120 N-m of torque on the lug-bolts. Check the manual!
Old 11-21-2011, 07:59 PM
MainlandMig's Avatar
I did this summer for the very 1st time.. I was hesitant after reading posts but what I did was i tested it on 1 lug.. Applied a small amount on seat n thread and tightened then immediately took it off to to see if it felt any easier to remove.. It didnt i also visually inspected the lug to see how much anti seize was on lug ...nothing significant .. So I decided to do them all and run them for a short while nbecause I knew I would have them all off soon after for a test fit of another wheel and I would test for looseness then. I had them off for the fitting 2 or 3 weeks later ...no issues they removed fine...Normal tightness... I took them off last month to run my stock wheels n did not reapply anti seize, just figured I did not need to... I'll decide on a reapplication in spring when I return to my summers.
Old 09-15-2015, 10:45 AM
solidjon's Avatar
Default Audi allroad wheel nut torque
Hi, have also been looking for this information on torque figures for wheel nuts on an Audi allroad 2.7T. mine is a year 2000 model in the UK.
After searching online and getting ideas, but nothing 100%, I've managed to find the proper information from the Bentley Publications Audi A6 Service Manual, which covers the following models 1998, 1999, 2000, 2001, 2002, 2003, 2004 A6, S6 allroad quattro, RS6.
In section 4, chapter 44-1, under the heading 'Tightening torque' it states 'Wheel bolt to wheel hub' 120Nm (90 ft-lb).
So if any of you are wanting this info, this is accurate from the A6 Service manual. I hope this helps anyone needing the same information. Also if you are putting wheel spacers to these A6 model, it is advisable to use the same torque figures as the wheel nuts, but REMEMBER after driving 100 miles with new spacers on, RECHECK and re torque the bolts on both the spacers and the wheels.
Old 09-15-2015, 10:51 AM
uberwgn's Avatar
Yeah, the correct value is 88 ft*lbs on this car.
Old 09-15-2015, 11:35 AM
  #18
royclark's Avatar
Originally Posted by ernestolopez
85 to 90nm.
This is wrong, It's 120Nm
Old 10-30-2017, 08:49 AM
  #19
QURRACI's Avatar
Default wheel nut torque setting for 2016 a6 3.0 c7
Any info?
Old 10-30-2017, 08:52 AM
  #20
uberwgn's Avatar
Qurraci, it's still 88 ft*lbs for the majority of Audi cars. The SUVs use different values.
If you wish to double-check, it's always going to be found in your Owner's Manual.
Quick Reply: Audi Wheel Bolt. How much torque?
