Mark this thread as Unsold
Audi Other 2002 allroad MT6 (Feeler)
Old 04-15-2014, 12:13 PM
jav
jav's Avatar
Default 2002 allroad 2.7T 6-speed Manual - $4500 OBO
I'm looking to sell my 2002 allroad 194,000 miles. It is a clean, well maintained, one owner vehicle. It is my daily driver so the mileage will continue to accumulate until it's sold. I am asking $4900.
If you're still reading, then you know that this car has a lot of life left but my growing family demands something bigger. I have owned the car since new. It comes well equipped with the 2.7T motor, manual 6-speed transmission, front and rear heated seats, heated steering wheel, adjustable height suspension, parking sensors, Xenon headlights, Bose sound system and the Audi tow package including two ball mounts (different drops), winter and summer floor mats (summer mats barely used), rear cargo tray, tinted windows, cargo cover, cargo divider (for those of you with dogs), nearly new Goodyear snow tires AND older Blizzaks (currently mounted) on 17" stock wheels.
Exterior -
No accidents!!! The paint is in excellent condition. All factory accessories and parts are installed, undamaged and in tact. Wheels are in excellent condition with only 1 small area of curb rash on one wheel. There are some small stone dings on the hood. Both headlights were recently redone with Griots headlight restore package.
Interior -
You would never guess that the car is 12 years old. Everything works! The leather is in excellent condition with minimal wear - no frays, rips, tears or stitching coming loose. Carpets show some wear but are in good shape with no holes including at the driver's heel. There is some soft-touch wear on the headlamp switch and the "+" for the driver's side climate control. The cargo cover and cargo net are both included and functioning. The rear center headrest is broken internally - it works but it flops around a bit. The rear cup holder cassette has been used as a footstool one too many times by my kids and it is broken. The center console cup holder no longer retracts.
History:
4/2/2014 - 193,030
Fixed the connection between the front and rear sections of exhaust
On the passenger side. The clamps rusted through and failed.
3/7/2014 – 191,250
Replaced front left upper forward control arm
Replaced front left upper rear control arm
Replaced Shock Mounting Kits
Replaced Left Front CV Joint boot
Install two new Bilstein shocks (Arnott warranty)
Replace right rear air spring (preowned unit)
2/23/2014 – 190,500
Refurbished headlights (Griots kit)
Driver’s side fog lamp bulb (H7)
1/20/2014 – 188,500
Replace flasher switch with stock Audi unit
Rebuilt rear window washer pipe, fixed broken washer line
Replaced hood strut
Replaced tailgate struts
Replaced cabin filter
Oil Service - Amsoil OE 5W30 + filter
1/17/2014 – 188,000
New Dunlop Winter Ice tires from Big Bear
1/8/2014 – 187,400
Battery – AutoCraft AGM battery
1/7/2014 – 187.250
Rebuild brake booster vacuum hose
10/20/2013 – 180,000
Rebuild secondary air injector pump
Flush heater core again
08/15/2013 – 176,000
Front half shafts and CV joints
Right front tie rod end
03/25/2013 – 172,000 miles
Left rear air spring replacement
02/04/2012 – 169,000 miles
Polished headlight lenses
Replaced flasher switch
Fixed front cup holder faceplate
01/01/2013 – 167,000 miles
Rear brake pads
Rear brake calipers
Rear brake rotors
Flush heater core
Engine Coolant Temperature Sensor (code)
11/30/2012 – 165,500 miles
Front shocks (warranty replacements)
Right front lower front control arm (the big one)
10/22/2012 – 163,000 miles
Timing belt kit (Timing belt, tensioner roller, idler rollers, dampener assembly and metal impeller water pump)
Camshaft seals (4)
Crank shaft seal (1)
Thermostat and housing
Tensioner gasket (2)
Camshaft plug (2)
Camshaft gear (2)
Valve Cover gasket set (2)
Vacuum line
Pinch clamps
Plastic pipe thingy on front of motor.
8/10/2012 - 155,000 miles
Valve cover gaskets
Cam adjuster gaskets
Cam end plugs
Three new spark plug boots (oil damage)
Air filter
PVC breather spider assembly (for crankcase ventilation)
03/13/2012
148,500 miles
exhaust flex pipes replaced with articulating joints
12/27/2011
145,000 miles
Air flow flap motor
Coolant flush and fill
11/12/2011
144,000 miles
Front air springs (Arnott Gen II)
Replacement front structs (Bilstien)
Air compressor (Arnott OEM)
02/08/2011
131,000 miles
09/2010
123,000 miles
Front struts, rear shocks,
front upper control arms, front lower control arm bushings.
01/22/2010
114,000 miles
Oil Service - Amsoil High Performance 5W30 + filter
01/09 95,000 miles
Front Axle Shafts
06/2008
86,000 miles
Timing Belt (recommended interval is 105,000 miles)
Water Pump
Thermostat
01/2008
Suspension Control Module
12/2007
Front Air bags
All Prior work was performed by International Audi, Milwaukee and North Shore Audi, Brown Deer.
Purchased new from International Audi, Milwaukee Wi in June, 2002.
The car is driven daily to my job 70 miles from home and has been about as reliable as a car can be. It's just time for something bigger.
Thanks for looking.
jav is offline
Old 05-04-2014, 04:27 PM
jav
jav's Avatar
More pictures.
jav is offline
Old 05-23-2014, 09:32 AM
moloveshisaudi1254's Avatar
Default Still for sale?
Is the vehicle still for sale? I sent you an PM.
moloveshisaudi1254 is offline
silent-w
03-08-2014 03:17 PM
Dr Dino
Canadian Discussion
06-02-2005 08:06 PM
craigd0013
01-10-2004 09:56 AM
Spdgeek
05-20-2002 09:50 AM
#41
02-10-2002 06:50 PM
Quick Reply: Audi Other 2002 allroad MT6 (Feeler)
