MMI Components
Old 02-08-2014, 11:47 AM
  #21
ESICA14's Avatar
Hmmmmm.....there are currently a few SW# 4F0 and 4L0 units for sale. But no 4E0.
HW# is the same, might they work?
Thanks
Chris
Old 02-08-2014, 12:17 PM
  #22
Banned
JohnnyJ A6Q's Avatar
You will need SW: 4E0 as that is for "A8", like Misha just stated the other SW versions cause "All menus are different and dimmed. It doesn't support MMI screen retraction"
As the A8 is the only one with retractable MMI screen it would not open of close, I could also see now that maybe Air suspension might not even show up on screen....
Old 02-08-2014, 12:20 PM
  #23
Banned
the two I linked to are 4E0 hardware and 4E0 software just like this one...
http://www.ebay.com/itm/Audi-A8-S8-4E-Interfacebox-Interface-4E0-035-729-A-4E0-910-730-A-090-/161194871739?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2587f68bbb
Old 02-08-2014, 12:21 PM
  #24
ESICA14's Avatar
Understood....thanks for your comments. Once I replace it I'll post with the results.
Best,
Chris
Old 02-08-2014, 02:57 PM
  #25
ltooz_a6_a8_q7's Avatar
Default Did you check the Head Unit cables
Before you change anything, I had the problem before with the MMI, dead, remove the CD changer, you can see the metal box behind it, try to remove or plug back in all the cablesptical and power.
I don't believe the box just die that easily.
If you have to get another box, get the "A" so in case you want to add the camera or watching TV, it's doable.
My wife actually enjoy TV watching while moving like snail in heavy traffic.
Cheers,
Louis
Old 02-13-2014, 10:28 AM
  #26
ESICA14's Avatar
I just plugged in the used MMI control unit I purchased and SHE'S ON!
Thanks VERY MUCH to all who posted and helped me with this!!!!
For all who have a similar Optical Bus Diagnostic in the future, just replace that Control Module and move on (I hope)
I'll run it through its paces and get back with any questions.
Old 02-13-2014, 10:36 AM
  #27
Default VCDS scan normally tells the devices problem
"07-Control Head......ERROR......ERROR "
Just like Johnny said... hardware and bus failed.
I'm glad you found the real problem.
Question? Any Component Protection Error?
Cheers,
Louis
Old 02-13-2014, 11:13 AM
  #28
ESICA14's Avatar
Cheers,
Louis
Hi Louis,
I don't recall seeing anything showing that error
Old 02-13-2014, 01:43 PM
  #29
Default Radio Works? Navigation works? NO mute icons? No CP?
Originally Posted by ESICA14
Hi Louis,
Did you have it replaced at the dealer ship or you did it yourself? I thought all Head Unit throw Component Protection of some kind? The Myth is proven WRONG?
Cheers,
Louis
Old 02-13-2014, 02:33 PM
  #30
ESICA14's Avatar
Cheers,
Louis
After putting it through it's paces everything works except for the Telephone. Its telling me
"phone not activated. Please visit your Audi dealership"
Anyway around that one with the VAG tool?
Quick Reply: MMI Components
