For Those Considering Swapping Wheels
Old 12-29-2013, 02:35 PM
  #31
tenspeed's Avatar
Originally Posted by loren48477
Anyway, can someone “in the know” tell me if the specifications I have listed for the 18” wheels match the OEM specifications for the wheel and tire that I listed? I also suppose I could purchase a wheel with a higher offset and use spacers to match the +39 offset. Comments, wisdom and advice are much welcomed!
RobC has put together a site that covers the specs of the Audi wheels. Lots of good info.
http://www.robcheng.com/audiwheel/
This is one of many tire calculator sites that deals with offsets and backspacing.
http://www.rimsntires.com/specs.jsp
One thing to realize is that a change of the width of the wheel will change the offset and backspace.
If you can, stay away from spacers. Buy wheels with the right offset. Spacers have been known to sometimes cause vibrations.
Old 12-29-2013, 03:53 PM
  #32
loren48477's Avatar
Tenspeed, thank you for the advice and for the links!
2013 A6 | Glacier White | Prestige | Innovation | 20” Sports Package
Old 12-30-2013, 01:23 PM
  #33
Ltdplus9's Avatar
I agree. My goal was to avoid spacers. Someone else on here told me that they went into a 35 offset and it fit fine. Just a much more aggressive stance.
Old 01-01-2014, 04:59 AM
  #34
loren48477's Avatar
Well nothing like having your question answered before it is even asked. I wondered if I could get away using a +35 offset and it looks like that will not be an issue. This is great since there are many more wheel options available with a +35 offset than there are for +39. So if I go with the 18” wheels and the +35 offset will there be any negative effects/impact on the car? Everything I have read suggests not but I want to make sure that I did not miss anything.
I also am interested in recommendations on an all season tire. In the part of South Carolina that I live in we rarely get snow/ice and if we did the car will stay in the garage until it melts which is usually a day or two. So all I really have to contend with in the winter are cold temperatures and rain.
And lastly, depending on where I look, I have seen the bore for the A6 listed as 66.5, 66.56 and 66.6 mm. I believe it is 66.56 mm and people are either rounding up or down to obtain the other numbers. Is this “assumption” correct? Thanks!
__________________________________________________ _______________________________
2013 A6 | Glacier White / Black Interior | Prestige | Innovation | 20” Sports Package
Old 01-08-2014, 05:03 PM
  #35
r1racer's Avatar
I am planning on throwing some 20's on in place of the stock 19's. What offset range am I looking at? Anyone have the 5 spoke ti wheels with the 35mm offset?
rayjr13
10
04-12-2016 04:43 PM
Dudealicious
Q5/SQ5 MKI (8R) Discussion
09-12-2015 03:51 PM
Dudealicious
11
09-05-2015 08:58 AM
anticsAK
09-04-2015 09:59 PM
mkirkpatrick
Wheels & Tires Discussion
09-03-2015 08:31 AM
Quick Reply: For Those Considering Swapping Wheels
