Suspension Settings on MMI - missing.
Very interesting and good looking suspension menu. Never saw one like that, but it makes sense with sport suspension. Having comfort, automatic and dynamic with virtually same height is not really useful. Neither speed limit under Lift, which is same as regular suspension Comfort. Than again not having more lift in a sport suspension doesn't make any sense. They should stay with stiffer sway bars and whatever they did with shockabsorbers and leave height options like standard.
Once it start working you must tell us what those settings are doing.
The green one wise, that showing you can't change. Go to APG something and check Air Suspension box.
Yeah, thatīs kind of my problem - that I canīt get the bloody thing to work
As I wrote earlier I went in [07] - Adaptation and chose channel 01 and entered value 64... Thought it to be the right thing to do after reading several posts saying "enter the value of the 64th". Before that I had no suspension menu at all, but then this appeared...
Does the Car View Option pic make any sence to you??
I would really like to get the right menu up and running!!!! This is getting somewhat frustrating...
it is interesting, havent seen that one before, I dont think we can tell the car to change to the one mishar has put up,
I dont know if this menu ever changes if mmi firmware is updated
it may be worth checking what mmi fimware you are running
but to be sure
go to the hidden menu
and make sure all of these are checked or have a setting, if you make changes go back in and see if the changes have taken place.
Car Menu Maske > Car View optionen >
there is an option called Air Suspension
check out
APK 0Ũ01, 0x0B, 0x0C
there is one near the end thats called charisma
APK 0x0D
Air Suspension
Car Menus Maske
Charisma
save it
reboot after changing them
but to be sure
check out
APK 0x0D
Air Suspension
Car Menus Maske
Charisma
save it
This is what I get from the "APK 0x0D"
And when hitting the "SET UP" I get the note about no further vehicle settings.
Under the hidden menu I have all the options as pic shows.
Ah, alright... So probably the menu wonīt change since Iīve updated the MMI to the latest version...
Strange though that I canīt get the "Lift" mode to show. Or to get the options activated at all, for that matter...
#20
