V8 quattro stuck throttle
Old 07-12-2011, 06:52 PM
1972bc's Avatar
Originally Posted by prdbloke
Here's what it was: the bearings on which the throttle butterfly valves sit, and their spring return mechanism, were sticky to an extent you would scarcely believe. presumably as a result of being left in one position for months. Penetrating oil plus a good deal of effort with the hands freed it all up. The rod mechanism that seems so implausible was functioning fine. The whole job need only have taken an hour or so for an able-bodied person.
My throttle stuck wide open today and bounced on the 7000 rpm rev limiter. I fixed it with your advice! thanks! I took pictures of the stuck parts and circled them in green. I used PB Blaster and wiggled it until it broke loose. Had to take out 6bolts and disconnect one hose to get to the butterfly valves on the front of the intake.
Old 07-15-2011, 08:50 AM
giantsteps's Avatar
Hi. Just curious if you are able to run the car with the exposed butterfly's like an old carb. I've got mine torn down as the photo's shows in this thread, and would like to pour sea foam down the throat. Thanks.
Old 07-17-2011, 03:46 AM
V8QinNJ's Avatar
Nope, The picture there shows what you would see as the "bottom" or past the butterfly.
Old 07-18-2011, 03:29 PM
1972bc's Avatar
Sea foam would go right in there and free up some stuck oil rings I bet, so good idea. I think it would run, but you should plug the big hose with something. The hose next to the butterflys. It'll run rough without the mass air sensor and idle control valve at low rpm. Better keep it around 1500 rpm or so.
My throttle is still working perfect. Not sticky at all.
three-and-out
A4 (B7 Platform) Discussion
06-13-2009 11:24 AM
gmontoya
05-08-2007 05:01 AM
Leeq
07-10-2003 02:09 PM
jam5285
06-12-2003 09:44 AM
A4 FL2
08-28-2000 07:13 AM
Quick Reply: V8 quattro stuck throttle
