Outer CV boot replacement procedure
Not the same bolt
1. Pop out center cap and remove drive axle bolt. This is
highly torqued so remove (and install) with the wheel on
the floor. Loosen the lug bolts.
I do not have a bolt here. I have a large hex key slot. What size hex is this and why do I have this and no one else seems to?
Thanks for the help.
While on the subject, here's an interesting link for those with the intelligence to replace only the boot/grease (instead of an inferior aftermarket complete axle) when only a torn boot is involved. A properly cared for OEM outer CV joint is good for a half million miles, unless it's gone way to long with a ripped boot and is actually clicking loud and causing pulsating steering wheel:
http://forums.quattroworld.com/a8/msgs/45872.phtml
How do all the tips show this regular bolt? Odd.
Thank you for the info. Looking for the allen bolt on Parts Geek... no luck, darn.
Very cool that I still have the original front axles. They have the 1996 date on them. My old Merkur Scorpio would be on its 4th set with the same miles.
alms_lefko
02-26-2008 07:26 PM
reefer_bob
01-09-2006 01:34 PM
