No heat at idle after some soft of coolant flush/drain/change/treatment? Here is fix
Old 01-03-2010, 12:58 PM
toddstebleton@mac.com's Avatar
I just started replacing my core yesterday. I did flush several times over the past year or two, but now I can smell coolant when running heat and the windows get foggy very easily, both signs of a bad core. So, I said what the hell. Turns out, it's not very difficult at all to disassemble the entire dash, but it does take time. If you have a little confidence and aren't afraid, it's not so bad.
I'm waiting for the new core for ECS tuning, then putting it back together may be a different story.
Old 01-03-2010, 01:48 PM
Tech Guru
4Driver4's Avatar
BTDT...well, I did the AC evaporator anyway. Too bad about your core; they are usually a low failure item.
Agreed about the difficulty. Lots of parts, but not really a terrible job. Following Bentley makes it much easier.
Old 01-03-2010, 05:42 PM
fimotorsports's Avatar
Originally Posted by 4Driver4
I use compressed air to bleed the system with the car off and the engine cold. Works great.
can you detail how you did this? I'm about to try this to try and fix my heat issue
Old 01-04-2010, 05:42 AM
Realistically, no. Providing a detailed write up would take me about 4 days to write. But, I will work with you as you are doing it. Definately use a manual. I used the Haynes, but I'm sure Bentley would have been better. Everyone says do t do it, but I think that's just the hype. Most people probably haven't actually dine it themselves. If you feel like tackeling it, go for it. It will save you over $1K.
Here are some things you'll need:
1. A warm garage that provides room on each side of car.
2. A shop to discharge your AC
3. New coolant to fill when your done
4. For tools, you'll need a ratchet set, Allen set, triple square set (or whatever it's called)
5. Patience
6. Plan for a good three to four days without your car.
Enjoy it!
Old 01-08-2010, 05:17 PM
Originally Posted by Peter Badore
Finished. Pushed coolant through the heater core with compressed air. Note the above there was no flow to the heater core feed line initially with the feed line disconnected and the engine running.
how did you do this exactly, as far as pushing coolant through with compressed air.
Old 03-04-2010, 10:08 AM
mikefmcnally's Avatar
Hi - I just bought a 2002 allroad and the heat worked when I test drove it. Yesterday when I was trying out the heat to see how it worked, it was blowing only cold air. I have the heat setting all the way up to high and the car was idle for 20 minutes.
I then shut the car off and let it sit for about 40 minutes, then started it up and it blew heat for the forst 30 seconds, then cold again. Does this sound like the air pocket issue above? The coolant was replaced when the car was services just before I bough it.
Also, do you happen to still have the photo mentioned above showing the bleeded line? I think I will try bleeding the line first.
Thanks!
Old 03-04-2010, 10:48 AM
Tech Guru
4Driver4's Avatar
The core is not properly bled. I'd take it back to whoever serviced it and have that fixed. Check the Tech Section for information on bleeding the system.
Old 02-24-2011, 12:06 PM
  #18
tdelaive's Avatar
Default How to pressurize?
How did you go about putting pressure on the system?
I've tried bleeding it but the -24 C temperature makes it a bit difficult to do this properly outside with the car running.
Old 12-17-2011, 02:19 PM
  #19
tboyd1971's Avatar
how do i preasurize system to get air out and get heat at idle ? please help
Old 12-17-2011, 04:02 PM
  #20
jcman's Avatar
Default Start a new post about your problem...........
........instead of reply to a really old thread first.
Harddrive2000
01-17-2011 09:26 AM
sugadaddy12
02-24-2010 01:23 PM
sidespar
12
11-27-2007 05:42 PM
gohardRgohome
1.8T Discussion
11-08-2007 03:44 PM
HIS4
10
06-10-2006 05:58 PM
Quick Reply: No heat at idle after some soft of coolant flush/drain/change/treatment? Here is fix
