Replaced ignition switch...car still won't start. Need advice.
Old 04-25-2008, 10:39 AM
dtompsett's Avatar
Default Nope... only relay is the solenoid itself. Definitely sounds like it's the trigger wire...
trace it back... make sure the connection is good, and double-check the connection on the new switch. Can you get at the switch to check the connection there? (ie, test the output voltage from the switch when the wire is connected... jam a test-probe from the voltmeter in the solenoid trigger wire connection).
Done anything else that could have shorted the wire?
Hate to say it, but triple-check the female-spade connector on the solenoid trigger wire. I had a slow/no-start issue with my Scirocco (same style connections), and turned out it was just too much rust on the connection/wire. Snipped 2" off, crimped on a new connection, and everything was golden.
Old 04-25-2008, 03:18 PM
rabbid's Avatar
Default fighting the same problem with a 90 CQ!
I'm going to go check for corrosion at the starter trigger wire...
Let me know if you find yours.
Jim
Old 04-27-2008, 12:19 AM
Junior Member
JazzGuitarist's Avatar
How old is the starter?
90CSaiko
06-01-2008 08:38 AM
lesk123
08-05-2007 06:59 AM
T90
Audi 100 / A6 (C4 Platform)
04-25-2006 04:56 PM
cursed_coupe
05-27-2005 08:11 PM
DCXninety
9
01-25-2005 05:02 PM
Quick Reply: Replaced ignition switch...car still won't start. Need advice.
