Frequently Asked Questions and Common Problems Thread Collection
Old 11-11-2005, 08:03 AM
  #51
Member
RedRoadster's Avatar
Default Re: Stupid/Silly/Ignorant Question ABOUT BRAKE SWITCH
I can't see how it would, unless you want to get: technical: what I mean is this scenario - you're driving along in cruise control, you hit a bump on the highway, and your defective/improperly installed brake switch is triggered - this will disengage cruise control the same way that stepping on the brake will, and you find yourself coasting down, closed throttle! So I guess, yeah, in that way, it makes you "lose" power, but I suspect that's not what you meant! I don't know what it costs since I had a couple replaced under warranty, though I suspect it can't be expensive. Labor, I'm not so sure if they need to drop the lower dash or not.
Old 11-11-2005, 09:06 AM
  #52
MarTT's Avatar
Suspension:
Old 11-11-2005, 09:07 AM
  #53
MarTT's Avatar
Default Bushing and Bearing replacement
<ul><li><a href="http://public.fotki.com/martt/audi_tt/mods/bushings/">Bushing and Bearing replacement</a></li></ul>
Old 11-11-2005, 09:26 AM
  #54
jayel's Avatar
window problems. the headlight switch problem
Old 11-11-2005, 09:27 AM
  #55
jayel's Avatar
Default 6 speed 225: 2-3 grind
supposedly mt90 redline oil helps, but i haven't tried it
Old 11-11-2005, 09:40 AM
  #56
hOz
hOz's Avatar
Parking light part #, replacement, 'whack' fix
Old 11-11-2005, 09:53 AM
  #57
Member
MOBlueTT's Avatar
What are the two (2) ways to get cables through the firewall
Old 11-11-2005, 09:54 AM
  #58
Member
MOBlueTT's Avatar
Good Idea ;-P
Old 11-11-2005, 10:19 AM
  #59
YosemyTT's Avatar
Offsets
Old 11-11-2005, 11:57 AM
  #60
That damn Dan's Avatar
Roadster's trunk light switch problem.
Quick Reply: Frequently Asked Questions and Common Problems Thread Collection
