Frequently Asked Questions and Common Problems Thread Collection
#131
How Silicone IC hoses are made....
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/sfs/sfs_performance-1/">http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/sfs/sfs_performance-1/</a</li></ul>
#132
How to install a Short Shift Kit (ECS)...
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/ecs_tuning_short/">http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/ecs_tuning_short/</a</li></ul>
#133
Quattro Rear Anti-Sway Bar (with grease zerts added)...
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/brakes_and_suspension/neuspeed_anti-swaybar/">http://public.fotki.com/mcphill/audi_stuff/brakes_and_suspension/neuspeed_anti-swaybar/</a</li></ul>
#134
OEM Rubber Dogbone Bushing Swap for Poly Bushings.
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/brakes_and_suspension/dogbone_bushing_install/">http://public.fotki.com/mcphill/audi_stuff/brakes_and_suspension/dogbone_bushing_install/</a</li></ul>
#135
Installing Stainless Steel Brake Lines:
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/brakes_and_suspension/stainless_brake_lines/">http://public.fotki.com/mcphill/audi_stuff/brakes_and_suspension/stainless_brake_lines/</a</li></ul>
#136
Installing a Beesting Antenna on a Roadster...
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/exterior_non-lighting/bee_sting_antenna/">http://public.fotki.com/mcphill/audi_stuff/exterior_non-lighting/bee_sting_antenna/</a</li></ul>
#137
Making and Installing a Grounding Kit...
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/interior_non-lighting/grounding_mod/">http://public.fotki.com/mcphill/audi_stuff/interior_non-lighting/grounding_mod/</a</li></ul>
#138
Installing a PhatNoise Music System in a Roadster...
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/interior_non-lighting/phatnoise_mp3_playe/">http://public.fotki.com/mcphill/audi_stuff/interior_non-lighting/phatnoise_mp3_playe/</a</li></ul>
#139
Ipod OEM Audi adapter install..>>
this is on my 2002 TTQC with Bose and the Concert II headunit but should work for any TT
<img src="http://tinypic.com/jts1sh.jpg">
Audi ipod adapter Part No.: 8E0-051-444
<img src="http://tinypic.com/jts2ae.jpg">
extra cables hmm...
<img src="http://tinypic.com/jts2gk.jpg">
WRONG cable for Concert II (that would have been too easy!)
<img src="http://tinypic.com/jts2mg.jpg">
CORRECT cable for Concert II... nope, no socket there
<img src="http://tinypic.com/jts2s9.jpg">
ipod cable
<img src="http://tinypic.com/jts2uo.jpg">
wire ties (how nice of them) and the adapter
<img src="http://tinypic.com/jts2zl.jpg">
note: my $5 radio removal tools from 42draftdesign didn't quite do the trick
autopsy later showed that even when fully inserted they're not long enough to 'click' in the latch. They depressed fully but I couldn't use them to pull out the radio.... a couple of flat blades did the trick!
<img src="http://tinypic.com/jts31u.jpg">
this bigger socket is what we need... bye bye CD changer!
<img src="http://tinypic.com/jts37o.jpg">
good to note how things used to be before taking apart (you never know!)
<img src="http://tinypic.com/jts3dz.jpg">
to get all the wires out you have to unlock (push out) the purple-ish tab on the side of the socket (not really clear from 'ikea-like' instructions)
<img src="http://tinypic.com/jts4qq.jpg">
pulling out didn't work in my case but a forceful push with a scredriver did the trick.. one at a time!
<img src="http://tinypic.com/jts4t5.jpg">
i decided to put the ipod in the center console... with the car out of warranty and all the horror stories here about broken latches ($$$) I thought not to tempt fate and stay away from the glovebox
pulled out the switches and drilled an opening for the cable in the back
<img src="http://tinypic.com/jts4zb.jpg">
snaked the cable through
<img src="http://tinypic.com/jts55g.jpg">
and
<img src="http://tinypic.com/jts5eh.jpg">
voila!
even though you really can't see the hole I didn't like it 'gaping' so
I cut a small hole in a rubber plug (just big enough for the cable) and now it looks more 'finished' with no gaps or openings.. also keeps the cable nice and tight
<img src="http://tinypic.com/jts5k1.jpg">
connected the adapter
<img src="http://tinypic.com/jts94m.jpg">
sheesh.. now the hard part!
put THOSE wires... in THAT socket
<img src="http://tinypic.com/jts8x1.jpg">
Before..
<img src="http://tinypic.com/jts9ao.jpg">
and AFTER
<img src="http://tinypic.com/jts9d4.jpg">
with some close-ups for future reference
<img src="http://tinypic.com/jts9ib.jpg">
<img src="http://tinypic.com/jts9l0.jpg">
remember to push the red locking tab back in!
<img src="http://tinypic.com/jts9qg.jpg">
without too much force and without pulling the wires out!
<img src="http://tinypic.com/jtsb3d.jpg">
tuck in the adapter neatly out of sight
<img src="http://tinypic.com/jtsb4z.jpg">
SAFE... ok my code was... SAFE
ok let's see... CDC...omg... it works!
<img src="http://tinypic.com/jtsb9d.jpg">
gratuitous AUDI logo on ipod
<img src="http://tinypic.com/jtsbba.jpg">
and you can do random!
<img src="http://tinypic.com/jtsbd2.jpg">
everything works as expected.. can access playlists FF/RW/SKIP
backlight times out as before and any press will bring backlight on but all controls are disabled
I really don't miss seeing the ID3 tag info
It does display on the ipod however
<img src="http://tinypic.com/jtsbhl.jpg">
... out of sight
worth the $150 imo but a bit of a PITA to rewire the socket
amazing sound quality (over FM-transmitters) and very convenient OEM integration with (somewhat) lower cost than icelink
Cheers!<ul><li><a href="http://www.clairparts.com/accessories4.asp?product_id=2471&PDID=201062"> ipod oem adapter</a></li></ul>
extra cables hmm...
ipod cable
and
voila!
Before..
and AFTER
... out of sight
#140
Dust & Pollen Filter Replacement (every 20K)
The dust & pollen filter is recommended to be replaced every 20,000 miles in the Audi TT (you may choose to replace more often in your climate). The part number is 1H0 819 644. A step-by-step how to is available at the link below.
New filter going in . . .
<img src="http://images15.fotki.com/v264/photos/4/41970/3067503/cabinfilter033-vi.jpg"><ul><li><a href="http://public.fotki.com/martt/audi_tt/photos-1/cabin-filter/">How to change the Dust & Pollen Filter</a></li></ul>
