Audi TT MK1 do not Start engine
Good time respected drivers Audi TT . My name is Marcel and I am from Russia . I have Audi TT has its specification below
Audi TT 8N quattro 1.8T 2000/10/11
VIN: TRUWT28N1110161 **
AMU 224hp/280nm.
Mileage 145000 km .
Engine block 06A - bored to suit 82.5mm diameter pistons .
Wiseso Pistons Forged 2.0 Stroke ( 82.5mm . Degree 8.5:1 compression 20mm finger)
Reinforced H -shaped rods Scat 144h20mm / bolts ARP2000
Crankshaft 2.0 TFSI. Stroke 92.8mm .
Inserts indigenous / crank - mahle.
Semicircles - Kolbenschmidt
camshafts - runoff.
New Gascom .
Cylinder head studs ARP.
Gearbox - 6-speed DQB
Front intercooler
Bypass - Forge motorsport.
Intake - K & N 3 " .
Coils - Bremi tfsi.
Gasoline pump - Bosh 044 in fuel tank
Fuel regulator - 4 bar .
Fuel rail - Stoke .
Nozzles - Simiens Deka 630cc.
Turbocharger GTX28r
Exhaust 3 " fully - Custom .
Intake manifold - stock .
Lubrication system - new oil pump + new chain and tensioner .
Sensors in the cabin - Lambda , charging , exhaust gas temperature .
please help , after assembly of the car engine will not start , starter motor turns but does not start .
I checked
all connections all plugs
fuses
candles
coil
sparking
compression (11 kg/cm2 , with the oil in the cylinder 14 kg/cm2)
fuel supply
resistance between pin 2 and 3 on the crankshaft (866 ohm)
Give below the result of scanning through vag com :
VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 K
Component: 1.8L R4/5VT G 0003
Coding: 06710
Shop #: WSC 01411
TRUWT28N111016173 AUZ5Z0Y9042318
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
1 Fault Found:
00813 - Sensor 2 for Brake Pressure (G214)
57-00 - Electric Circuit Failure
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8N1 920 930 J
Component: KOMBI+WEGFAHRS. M73 D54
Coding: 07044
Shop #: WSC 24102
XXXXXXXXXXXXXXXXX
2 Faults Found:
00771 - Fuel Level Sensor (G)
29-00 - Short to Ground
30-10 - Open or Short to B+ - Intermittent
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Address 35 -------------------------------------------------------
Controller: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15884
Shop #: WSC 01236
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
31-00 - Open or Short to Ground
Address 45 -------------------------------------------------------
Controller: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
01462 - Anti-theft alarm ultra sonic Sensor (G209)
53-10 - Supply Voltage Too Low - Intermittent
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
2 Faults Found:
01538 - Motors for Headlight Range Adjustment (V48) / (V49)
00776 - Level Control System Sensor: Left Front (G78)
Address 56 -------------------------------------------------------
Controller: 8N0 035 186 A
Component: Radio D05
Coding: 00517
Shop #: WSC 01236
End -------------------------------------------------------
I apologize for my English - because I use a translator .
Waiting for your advice
thank you with respect of Russia
AMU 224hp/280nm.
Mileage 145000 km .
camshafts - runoff.
New Gascom .
Front intercooler
Coils - Bremi tfsi.
Fuel rail - Stoke .
Turbocharger GTX28r
I checked
fuses
candles
coil
sparking
fuel supply
Coding: 06710
Shop #: WSC 01411
Coding: 18446
Shop #: WSC 01236
1 Fault Found:
Coding: 00140
Shop #: WSC 01236
Coding: 07044
Shop #: WSC 24102
XXXXXXXXXXXXXXXXX
2 Faults Found:
1 Fault Found:
Coding: 15884
Shop #: WSC 01236
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
35-00 - -
Coding: 00010
Shop #: WSC 01236
2 Faults Found:
Coding: 00517
Shop #: WSC 01236
Good time of day, dear colleagues.
In the photo when they tried to start the car is not assembled on the inlet seems that there is no turbo.
The turbine is very good =)
All checked out, everything was normal, but the car would not start! Reason was the fact that the fuel in the tank which stood for almost a year - have lost their properties and the car did not want to wind up on it. Tried to pour gasoline directly into the intake manifold and the car started up =)
https://www.youtube.com/watch?v=4HGImdffvZc Thank you all.
From Russia with love.
If you have intresting of my car look link bottom
Engine assembly process
Logbook of my car online dirve2.ru - Russian version
http://www.drive2.ru/r/audi/4062246863888373814/
Logbook of my car online dirve.net - English version
https://www.drive.net/r/audi/4062246863888373814/
sp757
03-18-2004 09:11 AM
