Old 04-22-2014, 02:35 PM
InnocentGuns's Avatar
Picked Amanda up today. (Car's name) had the tires balanced and it fixed the shake. Threw on a steering wheel cover. And drove around a bit.
Noticed it takes a lot of throttle to downshift and boy is she slow. A fair amount of engine noise. Of course I buy a cabriolet the day it rains. So couldn't dig into much today. Here is a shot of the inside.
Old 04-22-2014, 06:19 PM
grillage's Avatar
Manual swap fixes the slow
Old 04-22-2014, 10:21 PM
CRAZY_RUSSIAN's Avatar
engine noise, seafoam should help that, and yeah, a manual swap would fix the slow problem:-D, oil change for the trans might help a little
Old 04-23-2014, 03:12 AM
Okay so can I dump seafoam in the current oil, drive 250 or so miles, and change oil and filter or change oil then add seafoam and normal 3-5k OCI?
No cluster lights.. the far right **** is pushed in on cluster. Cant pull out.
Any HID headlights out there that fill up the headlight and marker to give it a clean look?
Old 04-23-2014, 05:10 AM
Looks like I found the headlight housing I want.
1DJ 005 995-071 (left) and 1DJ 005 995-081 (right).
Any recommendations on where to get them?
Also where to relocate the signals to?
Old 04-24-2014, 02:56 AM
Hahahahahahaha. Ha.
Okay. So my fun now begins. Drove the car for first day all is good. About 50 miles or so.
2nd day a rock chips freshly painted hood and chips windshield. I have glass coverage so can get that repaired no problem. Drive to work this morning and cel comes on. ::face palm::
So new plan of action.
Scan code when I get home. Talk to dealer about fixing even though it was sold "as is". Since they clearly reset and didn't disclose a cel condition.
Order voltage reg for cluster since gauges are off and no cluster lights. $48 and 3-5 days.
If all of that gets fixed I will drain and fill transmission.
Then I will order timing belt kit and do wp, t stat, belts, ect.
Antenna is kinked so will need new mast. Haven't looked into wiring or motor yet.
Old 04-24-2014, 10:24 AM
hubturn's Avatar
Grillage is 100% right on the antenna. Go to the dealership and buy the thing right now. There are 36 of them out there, minus the one I just ordered as a backup. You can't buy an aftermarket one worth a hoot for $29 so this is a no-brainer. Heck, the mast itself is $70. Unless I am mistaken, there is an easy test for the instrument cluster voltage regulator, which I hope you have done before ordering it. Naturally, you checked the fuse? Instrument cluster removal is really easy. A Bentleys manual would be useful to you.
Jon-1.8t
02-16-2007 07:42 AM
EuroTrasher
04-17-2006 06:29 PM
GVee
12-30-2005 07:42 PM
tapdancer
06-24-2003 08:58 PM
Buckeye A4 3.2
9
06-11-2002 08:40 AM
Quick Reply: New Member
