Change that ATF! Picture of my fluid
Old 10-29-2013, 06:42 AM
that_tg's Avatar
Originally Posted by viper04
that_tg
Nice, just wondering where you got your kit from.
Bought the fluid from here
http://www.thectsc.com/catalog/6_speed-58.html
Funny thing, and do not let this one out. I ordered 7L from them and they sent me a case.... Yes, 12L. shhh. I could not believe it. I had to get back to my computer to confirm the amount I ordered and payed for. Must have been one nice or lazy worker.
The filter and gasket I bought as a kit from ECS tuning. The gasket was the right shape but was for a trans with many more bolts than my trans has. I did not use any gasket. The pan has a think metal gasket as original and I just bolted it back as it came off. Easy as it gets. Now I need to return the gasket if I can.
Old 10-29-2013, 06:53 AM
that_tg's Avatar
Default Check it
Originally Posted by 2k4blacka8
Wow, that fluid is blacker than motor oil lol. Routine maintenance is always key and you shouldn't wait until you have a problem.
How do you check the fluid level since there's no dipstick?? How many qts does it take??
There is no good way to check the level.
If you had the car up, running, and in Drive. Then opened the fill bolt.... Then you could add fluid until it spilled out. That is the only way.
Might as well drain it and fill it.
Use the process for the original A8 trans for this trans.
I did not give the trans much time to drain... Maybe 4 hours of sitting. and it took 5.5L to fill to full.
Here is the process
http://www.audipages.com/Tech_Articl...servicing.html
The 2007 transmission was easier than the 1997 to access.
Old 10-30-2013, 10:49 AM
that_tg's Avatar
Now that I have the "extra" ATF. What if I change the fluid again in say... 10,000 miles. It was so dirty and probably only changed out half of the total fluid in the car.
Good idea?
Old 10-30-2013, 11:03 AM
MP4.2+6.0's Avatar
Default If you want to be thorough, yes.
You perhaps got 60% give or take. The rest was in the torque converter and maybe some cooling lines and such. Doing it again will get the next .6 x (1-.6) = approx 25%, or 85% total. A few who have converted to one of the other fluids (gold to blue, gold to green) have mentioned doing it three times, which should approach 95%. Presumably skip the pan pull and any filter change in the next ones and save a bunch of time and mess.
Old 10-30-2013, 02:17 PM
bmwm750's Avatar
Good idea?
If you really want to get more of the old fluid out, absolutely. You could easily skip the pan drop and filter this time around.
Old 10-30-2013, 06:47 PM
that_tg's Avatar
Good point!
Would not have to take that brace beam out either. Drain and fill. This time I am going to let it drain overnight.
Old 10-30-2013, 08:12 PM
bmwm750's Avatar
Good point!
Given how gross yours came out, I'd be inclined to do the second drain and fill soon, then do a third in another 10k (and take note of how nice the fluid looks as it comes out). If all is well, at that point you could go another 50k (if you keep the car that long).
Old 10-31-2013, 06:06 AM
  #18
that_tg's Avatar
Right, if the fluid is no good why wait with bad fluid. I will post the picture of the second round fluid when I do it. Off to a hunting trip this weekend. Will give it a go next week.
nickcarguy
17
02-03-2016 04:33 PM
hotm6654@hotmail.com
12
07-13-2009 02:29 PM
mikesd1980
07-02-2008 07:09 PM
allroad(s) lead 2Gavin
Audi allroad
05-21-2007 03:02 PM
lskolnick(original)
10-11-2002 03:48 AM
Quick Reply: Change that ATF! Picture of my fluid
