A4 2.8 diagnosis help needed
Old 09-07-2012, 12:25 PM
CedarAudi's Avatar
Default A4 2.8 diagnosis help needed
Car is very hard to start and when it does start, chugs badly and blows white smoke like an insect fogging machine. If I slowly bring the revs up it will clear itself out and have normal exhaust and no missing. This is usually above 2500 rpm. As soon as I let the rpm's drop it starts all over again and will not hold an idle. There does not seem to be any unusual mechanical noises when this is happening. Could all this be caused by the purge valve?
Old 09-07-2012, 01:25 PM
GTA_Driver's Avatar
Did you have the car scanned?
Your likely culprit is the coolant temperature sensor. A $20 part from the dealer.
Old 09-08-2012, 07:32 AM
turbo510's Avatar
First find out what's blowing out the exhaust; fuel, oil, or coolant. You should be able to ID which it is by smell, but also pull the spark plugs (all six) and see if they all look the same. Do that and report what you find.
Old 09-11-2012, 08:35 AM
Former Vendor
ALLDATAdiy INFO's Avatar
Alldatadiy.com has diagnostic code as well as how to fix them. Good luck with your search.
Old 09-11-2012, 09:24 AM
turbo510's Avatar
Isn't ALLDATAdiy.com selling something? I know that you paste this same paragraph in every topic, but shouldn't this be in a classified section?
Old 09-11-2012, 11:58 AM
Tech Guru
4Driver4's Avatar
Vendors can post this stuff here. Usually they use some restraint and attempt to either contribute to the forum or at least post relevant content. Shameless shilling is obnoxious. Needless to say, I will avoid using Alldata and would urge you all to do the same.
Jcru111
09-22-2018 12:26 PM
CedarAudi
30v V6 Discussion
09-07-2012 08:42 PM
spetsnaz55
04-30-2010 08:49 PM
RS4000
11-15-2007 06:21 AM
Type. K
11-27-2006 07:17 PM
Quick Reply: A4 2.8 diagnosis help needed
