Audi 100/A6 (C4 92-97) FAQ Digest
Old 01-03-2004, 08:11 AM
beep-beep's Avatar
Default Moonroof Leak/ Rain Channel Repair
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/11903.phtml">click here</a></li></ul>
Old 01-03-2004, 08:12 AM
beep-beep's Avatar
Default hood latch broken
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/31615.phtml">click here</a></li></ul>
Old 01-03-2004, 10:18 AM
greenaudi100's Avatar
Oil Choices/Problems/Suggestions
Old 01-04-2004, 06:08 PM
engine
Old 01-04-2004, 06:10 PM
Default Fuel Filter Replacement Procedure
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/30492.phtml">Click here for procedure</a></li></ul>
Old 01-06-2004, 05:07 AM
netsatwork's Avatar
Alarm System
Old 01-06-2004, 05:08 AM
netsatwork's Avatar
Default Reset remote '96 A6
From Technical Bulletin 96-95-05 "Central Locking, Radio-Controlled"
-In addition to transmitters (remotes), two vehicle keys are also needed for coding.
- Switch on ignition.
- Using second key, slowly lock vehicle at driver's side door lock, smoothly without jerking key in tumbler.
- Activate both transmitter (remote) buttons for at least 4 seconds.
-- The system should now be functional.
(For additional remotes...)
- Lock vehicle again at driver's side door lock, turn key slowly and smoothly in tumbler.
- Activate both buttons of second transmitter for at least 4 seconds.
(Continue for up to four transmitters)
-- When coding is completed, central locking is functional
I added the stuff in parenthesis. It works great now. I thought I was going to have to replace it. Just FYI for everyone. Thanks.
Old 01-06-2004, 05:11 AM
  #18
netsatwork's Avatar
Default Oil Filters Picture (shows part numbers)
<center><img src="http://pictureposter.audiworld.com/41000/audi_oil_filters.jpg"></center><p>
Old 01-06-2004, 08:44 AM
  #19
manuva's Avatar
Axles, suspension, etc
Old 01-06-2004, 08:46 AM
  #20
manuva's Avatar
Default Replacing axles with rebuilt ones
If your CV joint goes, one option is to replace the axle with a rebuilt one (~$70 online).<ul><li><a href="https://forums.audiworld.com/a6100/msgs/22932.phtml">Click here</a></li></ul>
Quick Reply: Audi 100/A6 (C4 92-97) FAQ Digest
