VAG-COM Discussion
Blower Motor Faults
Old 02-20-2014, 03:14 PM
benpitt's Avatar
Default Blower Motor Faults
I'm looking for a little assistance since I am an inexperienced VAG-COM user.
Symptoms are no fan blowing out of any vents on floor or dash. Checked 30 amp and 10 amp fuses on right side of dash and they're not blown.
Scan Results:
Thursday,20,February,2014,17:45:02:30770
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAULL44E45N003086 License Plate:
Mileage: 185890km-115506mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAULL44E45N003086 Mileage: 185890km/115506miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 1010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: -------- Serial number: AUX3Z0D5743982
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 285513799B8B295EFC3-807D
6 Faults Found:
18284 - Valve for Torque Support Mount
P1876 - 004 - Open Circuit - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
16688 - Cylinder 4
P0304 - 001 - Misfire Detected - Intermittent
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
P1653 - 001 - - Intermittent
18043 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0010
Revision: --H01--- Serial number: 0037533
Coding: 0000002
Shop #: WSC 00012 785 00200
VCID: 3261F111AD57538E527-8067
3 Faults Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:29:21
Freeze Frame:
RPM: 672 /min
RPM: 320 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 65.0°C
T.B. Angle: 60.0°
18289 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:29:21
18005 - Powertrain Databus
P1597 - 000 - Missing Message from Level Control System (J197) - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:30:21
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 22410151FDB7C30EA27-8077
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
02083 - Message for Delay Request
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0D5743982
Coding: 0410624
Shop #: WSC 25167 444 54155
VCID: D8B5E3B96B6BD9DE0C3-808D
Subsystem 1 - Part No: 4E0 905 852 D
Component: ELV 1834
1 Fault Found:
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:30:06
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
VCID: 234F0455E2ADCA06A91-8076
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 303DG067521292
Coding: 0000003
Shop #: WSC 25166 444 84618
VCID: 2F67F865BE657E663D9-807A
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 317FX047529296
Subsystem 3 - Serial number: 7424.06.040000000000010030ÿ
Subsystem 4 - Serial number: 010030ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0300
Revision: 00000025 Serial number: 00000000047337
Coding: 1053121
Shop #: WSC 02311 785 00200
VCID: 1B3F3CB5DADDF2C6611-804E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO26052004065A000000000019ÿ†89
Subsystem 5 - Serial number: 000019ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO26052004065A00000000
Subsystem 7 - Serial number: 65A000000000018ÿ
2 Faults Found:
01273 - Fresh Air Blower (V2)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 85
Reset counter: 111
Mileage: 184454 km
Time Indication: 0
Date: 2013.12.04
Time: 15:24:36
Freeze Frame:
Temperature: 21.0°C
Speed: 0.0 km/h
(no units): 62.0
(no units): 172.0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 150
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:30:07
Freeze Frame:
Bin. Bits: 00000111
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
Component: ILM Fahrer H12 0190
Coding: 0123113
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0040
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Revision: 00000000 Serial number: AUZ5ZBD4014380
Shop #: WSC 00000 000 00000
VCID: 193326BDD0E180D673D-804C
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 A HW: 4E0 035 593 A
Component: SDAR
Revision: 0000000 Serial number: AUZ4Z7D60
VCID: 254B1A4DEC993436C75-8070
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 4
Mileage: 184251 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 075
Raw, Form. N/A: 000 000 000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 244D0749E7A3CD3ED0B-8071
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: E5CBDA4D2C197436875-80B0
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0080
1 Fault Found:
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:41
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H47 0200
Revision: D02 Serial number: AUDID3D5000549
Coding: 0016208
Shop #: WSC 44335 000 1048576
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 05005045131BE0
Coding: FCFE7BDD1B2B04
VCID: 26491D41919F3F2ECEF-8073
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:29:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:30:03
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:30:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:41
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:32:11
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV 1834
4E0905852D ELV 1834
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:30:06
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
2 Faults Found:
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 41
Reset counter: 151
Mileage: 184253 km
Time Indication: 0
Date: 2013.11.25
Time: 17:18:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:29:22
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 E HW: 4E0 919 887 C
Component: MNS US H43 0560
Revision: 00000000 Serial number: 355FN047528420
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 40
Reset counter: 148
Mileage: 184331 km
Time Indication: 0
Date: 2013.11.29
Time: 12:59:51
Freeze Frame:
Hex Value: 0x0000
Distance: -35.6 mm
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000413200241
Coding: 0003479
VCID: 1D3B32ADC4C9FCF69F5-8048
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:32:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0032364
VCID: 20450B59F3BBD11EB43-8075
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:34
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040406170297
Coding: 0065256
VCID: 2757104596952626F59-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:29:22
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:47
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 H HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0370
Revision: Dev_D01 Serial number: 00000000002261
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:41
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000042590
Coding: 0010111
VCID: 1E3935A1C9CFE7EE86F-804B
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0E35E
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:30:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:29:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRMH01 0060
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:36
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:29:21
Freeze Frame:
Voltage: 11.49 V
Count: 241
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2C1C1513D37030E627-80B7
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 185896 km
Time Indication: 0
Date: 2014.02.20
Time: 17:29:21
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 185896 km
Time Indication: 0
Date: 2014.02.20
Time: 17:30:21
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 185896 km
Time Indication: 0
Date: 2014.02.20
Time: 17:30:21
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304FT047596742
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000002484
Shop #: WSC 25167 444 59361
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1406180138
Coding: 344530393135313035412056413031343036313830313338
Shop #: WSC 00000 128 00289
5 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Time Indication: 0
Date: 2014.01.07
Time: 14:45:46
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 185545 km
Time Indication: 0
Date: 2014.02.04
Time: 07:23:02
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 185545 km
Time Indication: 0
Date: 2014.02.04
Time: 07:23:12
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:40
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 151
Mileage: 185890 km
Time Indication: 0
Date: 2014.02.20
Time: 17:29:22
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:36
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010027 Serial number: 00000700025489
Coding: 0202125
Shop #: WSC 25167 444 84593
VCID: DFC7C8A50E452EE64D9-808A
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 217
Reset counter: 111
Mileage: 184251 km
Time Indication: 0
Date: 2013.11.25
Time: 16:14:27
Freeze Frame:
Speed: 0.0 km/h
Temperature: 6.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Mileage: 184264 km
Time Indication: 0
Date: 2013.11.25
Time: 18:55:10
Freeze Frame:
Speed: 58.0 km/h
Temperature: 6.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 151
Mileage: 185888 km
Time Indication: 0
Date: 2014.02.20
Time: 17:31:34
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 B
Component: Telematik USA1 0080
Revision: 00000004 Serial number: 0000ATD3010929
Coding: 0000005
Shop #: WSC 25167 444 57943
VCID: E0C5CB59303B111E743-5072
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730417000688
Coding: 0001208
VCID: 21430E5DF8B1D816BBD-8074
End ---------------------------------------------------------------------
Any help is appreciated! I've ordered a blower motor and it should be here Saturday but I'm worried it may be something else.
Thanks in advance!
Ben
Old 02-21-2014, 07:26 AM
jakematic's Avatar
Have you run the output tests ? http://wiki.ross-tech.com/wiki/index.php/01273
I'm a bit concerned the Climatronic module might be bad since it's all over the Autoscan.
I would:
- clear DTC's
- run output tests
- replace blower motor if bad
- scan again
Based on the chassis number it looks like you have a D3, VIN tells me it's a 2005.
May also want to ask in the D3 forum as several member have experience with blower motor issues.
bballfreak
9
04-14-2019 06:59 PM
Kerry G
05-18-2018 06:12 AM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
hardipk5
10-02-2015 08:32 PM
Bruce B
Q5/SQ5 MKI (8R) Discussion
09-25-2015 12:11 AM
Quick Reply: Blower Motor Faults
