VAG-COM Discussion
Coding Help - Equipment Number Invalid
Old 02-19-2014, 09:58 AM
tdawg183's Avatar
Originally Posted by jakematic
Not sure if this is you tdawg, but amazingly similar issue on the Ross-Tech forum: http://forums.ross-tech.com/showthre...nge-(0-262143)
Thanks for that, it's definitely not me.
His solution was to remove the "0" by changing the "1048576" to "148576.
Would it be safe for me to simply remove a digit from my "892928" since I don't have a "0"? or should I still call Ross-Tech?
Couldn't I just change it and then try to change back if an error occurs?
Old 02-19-2014, 10:01 AM
jakematic's Avatar
I *think* it would be safe to do, and as you said you could always change it back - I *think*.
Best bet is to post on the other forum or contact Ross-Tech directly.
Am curious to know the outcome.
Old 03-03-2014, 01:34 PM
tdawg183's Avatar
So I eventually contacted Ross-Tech on this issue. Their recommendation was to change the WSC/VZimporter/Equipment numbers to non-zeros within the User Interface and Identification options.
I changed the WSC to 01234, the VZ/Importer to 444, and the Equipment number to 12345. I then made the Module code changes and it worked.
Hope this helps somebody.
Old 03-04-2014, 05:03 AM
jakematic's Avatar
Good to know, thanks for the update !
I suspected those numbers we arbitrary but not knowing for sure am glad you checked with the experts.
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
eggsngrits
12-08-2021 06:58 PM
Aman Singh Parhar
11-29-2016 05:03 AM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
mdkv5
A6 (C7 Platform) Discussion
09-16-2015 01:09 AM
Quick Reply: Coding Help - Equipment Number Invalid
