VAG-COM Discussion
Coding Help - Equipment Number Invalid
Old 02-15-2014, 12:01 PM
tdawg183's Avatar
Default Coding Help - Equipment Number Invalid
I'm attempting probably the most well-known mod of removing the seat belt chime and am having an issue. Every time i try to change the software coding (in this example the second to last digit from 6 -> 0) I get an invalid equipment error. See attached image.
I've not changed the equipment number at all and as you can see it is already pre-populated as a value outside of the listed limits already.
Any ideas on a solution?
Old 02-15-2014, 07:10 PM
jakematic's Avatar
I can barely read the attachment, but it looks like your WSC is 00000 indicating the module has never been (re)coded.
See here: http://www.ross-tech.com/vcds/tour/o...creen.html#WSC and also the bottom of this page: http://www.ross-tech.com/vcds/tour/a...on_screen.html
The Equipment Number field is used most often when coding new control modules.
Some control modules will refuse being recoded if they're not given an equipment number (sometimes they require a non-zero WSC and Importer number too).
The default value is 00000.
Some control modules do not allow themselves to be Coded with the default 00000 Equipment number in place.
VCDS should prompt you with a message to input non-zero values in such cases.
You should NOT make such changes in the Options screen itself.
So I would suggest putting 12345 in the WSC and trying it again.
Let us know if that works.
Old 02-17-2014, 09:50 AM
tdawg183's Avatar
Correct, the WorkShop Code is 00000.
According to Ross-Tech it appears that I should leave that as-is:
"Note: If you are an individual user or independent mechanic, just leave the WorkShop Code set to "00000". This allows VCDS to operate in “stealth” mode, keeping whatever WSC that was already in the controller."
My problem is the Equipment Number... It reads 892928 which is above the limit specified by VCDS (0-262143). The exact error is is follows:
VCDS: Re-Code Invalid
This equipment number is invalid!
Equipment number must be 5-6 digits: 00000-262143
Old 02-17-2014, 10:39 AM
jakematic's Avatar
Sorry - got down a rathole trying to read the screen shot.
What is the Equipment Number in the options screen of VCDS set to ?
I could be wrong, but think that is an arbitrary number to identify the machine at the 'workshop'
Mine is all zeros
Old 02-17-2014, 10:42 AM
tdawg183's Avatar
Mine is all zeros
Good point, I'll check it out this evening and post back. I've found this issue one other time on a VW forum and the suggesting was to change it to 12345. The solution worked but seems sketchy IMO.
Old 02-17-2014, 01:43 PM
tdawg183's Avatar
I was just able to confirm that my 'User Interface and Identification' options were all exactly as yours are set. All to zero.
Any suggestions on a solution?
When you check channel 17-Instruments coding, what are the parameters set at aside from the software coding... specifically the equipment number. Is it safe for me to change?
Old 02-17-2014, 03:39 PM
jakematic's Avatar
Hmmmm.
Post up a full Auto Scan text, maybe I can get a better idea.
Failing changing it to mine or something random, contacting Ross-Tech.
Before doing anything make sure to save/copy your full Auto Scan so you can go back.
This is what it was on my D3:
Code:
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 950 G    HW: 4E0 920 950 G
   Component: KOMBIINSTR. VDO H53 0210
   Revision: D05         Serial number: AUDID3E0004043
   Coding: 0016233
   Shop #: WSC 09222 444 14580
   VCID: 2855F28CE275
No fault code found.
Believe the breakdown is WSC=09222, Importer=444, Equipment #=14580
Old 02-18-2014, 06:12 AM
tdawg183's Avatar
Hmmmm.
The following is from a scan I did last night:
Part No SW: 4E0 910 951 F HW: 4E0 920 951 F
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F7000125
Coding: 0048263
Shop #: WSC 00000 000 892928
VCID: 285FFEE49B70635EFC3-807D
Looks like all the WSC & Importer are zeroed out but the equipment number is 892928. Again, this is weird because that number falls outside of the available range to set it in VCDS. Seems to me that if it's only a shop number that i'd be cool to change it to 12345 or something similar. Logically it doesn't make sense that this would affect the performance of the channel.
Old 02-18-2014, 06:39 AM
jakematic's Avatar
I'm going to have to defer to Ross-Tech on this one.
If it were just about anything other than module 17 I'd say just change it, but.....
Old 02-19-2014, 06:40 AM
jakematic's Avatar
Not sure if this is you tdawg, but amazingly similar issue on the Ross-Tech forum: http://forums.ross-tech.com/showthre...nge-(0-262143)
Quick Reply: Coding Help - Equipment Number Invalid
