VAG-COM Discussion
Deciphering what's already installed
Old 02-11-2014, 08:09 AM
tdawg183's Avatar
Default Deciphering what's already installed
Hey guys, i know this has probably been discussed many times but I'm having a terrible time finding an answer.
Super simple question:
What's the best way to figure out what is already installed on my car when using VAG-COM. When reading values for certain channels it just gives me the current sum. Do i actually have to break that down manually considering all possible options to know the answer to my question?
More specifically I'm wondering if my '07 S8 has the DIS (driver info system) currently active. The options suggest it's installed but I don't see it in the MMI.
Old 02-11-2014, 08:47 AM
jakematic's Avatar
Yes.
Well yes, kind of - the Installation List screen can give you a lot of information too.
Easier way may be to look at the PR codes on the sticker in the manual, or alternatively on the one in the trunk under the spare.
Looks like:
You can then punch those into one of the Audi PR code translators online to see what is installed such as:
PRCode: 0GM = emissions concept LEV 1
PRCode: 0JZ = without determination of weight categoryfor front axle
PRCode: 0YZ = without determination of weight categoryfor rear axle
PRCode: 1BK = 4-corner air suspension with electronic shock absorption control
PRCode: 1KW = disc brakes, rear
PRCode: 1LL = disc brakes, front
PRCode: 2K2 = reinforced bumpers
PRCode: 2ZM = leather trimmed multi-function steering wheel
PRCode: 3FE = electric slide/tilt sunroof with sun screen/sunblind
PRCode: 3PN = electric seat adjustment for both front seats with memory system
PRCode: 3Y5 = electrically operated roll-up sun screenfor rear window and mechanically operated for side windows
PRCode: 4GP = windshield tinted with sun band and viewing window for vehicle identification number
PRCode: 4K7 = central locking system "Keyless Entry" with safety radio remote control
PRCode: 4KC = side and rear windows tinted
PRCode: 4UH = airbag for driver and front passenger with knee airbag
PRCode: 5D2 = carrier frequency 315 MHz
PRCode: 5RW = outer right rear view mirror: convex, USlarge viewing field
PRCode: 5SG = outer left rear view mirror: flat
PRCode: 5Z0 = without separate power seats rear
PRCode: 6XL = outer rear view mirrors: powered, heatedelectrically foldable, automatically dimming, with memory function
PRCode: 7K3 = tire pressure control, frequency 433 MHzhigh level version
PRCode: 7Q2 = navigation system with color screen
PRCode: 7TC = decorative inserts, birch vein
PRCode: 7X0 = without park distance control
PRCode: 8ED = bi-functional headlight with gas discharge lamp, for driving on the right
PRCode: 8Q0 = without headlight-range adjustment
PRCode: 8Z6 = engine cooling system, type 2
PRCode: CG3 = cast alloy wheels 8 1/2J x 18 offset 45
PRCode: D0G = 8-cyl. gas. engine V8 4.2 L/246 kW 40V camshaft adj. w/o cylinder cutout, MPI base engine is T81
PRCode: E0A = no special edition
PRCode: F0A = no special purpose vehicle, standard equipment
PRCode: J0Z = battery 520 A (110 Ah)
PRCode: Q2J = comfort front seats
PRCode: T81 = components for base engine, unit 077.B
PRCode: U1B = instrument insert with mph speedometer, clock, tachometer and trip odometer
PRCode: X9A = national sales program USA
DIS is the display between the speedometer and tachometer.
Not sure exactly what you mean by DIS - like lane assist ?
Old 02-11-2014, 03:39 PM
tdawg183's Avatar
Wow, thanks. I'll check all that out.
As for DIS, yeah, you're right I just saw a post suggesting you can access the trip info (as you do on the screen between the speedometer and tachometer) through the MMI that confused me a bit. I was trying to figure out if that was already enabled or not. Sounds like it is (in the DIS) and simply isn't available on the MMI screen
Old 03-21-2014, 08:36 AM
jakematic's Avatar
Additional info on decrypting long coding: http://forums.ross-tech.com/showthre...ing-Decrypting
xkahn
02-08-2018 10:43 AM
AlllRoad
09-15-2015 12:51 PM
ECS Tuning-Audi
Audi A3 / S3 / RS 3
09-11-2015 11:56 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
Quick Reply: Deciphering what's already installed
