Torque converter
#21
Being fixated on the credibility of one source provided as one of many documenting and solving the known issues of the trannys is not the focus of my time and presentation in this thread. Quite frankly, based on contribution potential; I heavily weight the expertise presented by one local specialty tranny shop in anywhere U.S.A. vs. the ideology of the counter-opinion.
And, after reviewing the TSBs, I'm not sure I see anyone that applies to what the OP or I are experiencing, at least for me. There is quite a discussion on AudiZine on this subject, all of which point to replacing the TC. I have no shift problems, no noises. Just cold start 200 RPM surges in 4th, 5th, and 6th depending on the hill I'm going down.
Here's a good thread from audizine. http://www.audizine.com/forum/showth...-at-low-speeds that pretty much sums it up for me.
Not saying that the 9L doesn't have valve body or solenoid problems, but ZF, Eriksson, Nashua Audi, and my indy are all suggesting TC albeit over the phone. I've gone through the TC issues in both my C4 and C5. In the case of the C4, a fluid change solved the problem. In the case of the C5, had to change the TC.
#22
In Europe, the skilled diagnostic mechanics are changing the Mechtronic Unit (ZF lingo for valve body) for the definitive fix, with Sonnax solenoids. Many places that service the NAR version are following the trend. The tranny in the C6 Quattros is widely used in many European models and makes; BMWs, Jags, etc. It is ZF's second generation 6 speed for the world. Personally, I think mechanical perfection can not be of this world; striving for expectations that match standards of acceptability are. Whichever way people can attain the level of functionality they expect; more power to them and all the variables that meet those ends to address design imperfections. I am spending time on this topic because C5s are getting to old to own, and the C6's are aging into the point which it may take more effort to keep the herd strong and able, as well as the re-sale price as high as possible.
Also, Sachs makes the right fluid spec (Lifeguard 6) for the ZF 5HP19 for $25 a container via Amazon for free shipping in U.S.A. , for those on a budget with DIY skills.
#23
It seems we may have a collective protocol scale developing on this thread by price of intervention and scale up to the big T.C. change for rev flair issues. Fluid/filter change. No work, re-use fluid for rebuilt valve body change with tranny in place. No work, review the cost of the the T.C. change in labor. It requires to drop the box. Some guys can do it proper, DIY; but most may opt for a rebuilt whole unit replacement at a shop or dealership to keep the vehicle. Thanks for the topic, discussion, and research on this topic to all.
#24
You mean you saw the RPM needle dance like in this video?
So I had this issue and was able to reproduce this very easily since I live up a hill. When cold and coasting if you don't apply any gas, the rpm needle dances. Audi replaced the TQ convertor, replaced the fluid (twice), upgraded the software - nothing solved the problem.
There is nothing wrong with your TQ convertor - this is something software related (the engine revs up a little) and I have not seen any issues over the last 70k miles since I first noticed this issue.
Audi (including Audi of America) is unable to find the cause for this problem.
#25
#26
Don't worry about the C6 resale price - if you can even find one (at least an Avant any way).
#28
http://www.zf.com/na/content/media/u...omendation.pdf
By doing a service drain with different fluid, it essentially affects the friction modifier dilution ratio in your box.
#29
ZF introduced the Lifeguard8 not Audi. But yes, the 05-6 models did have the Lifeguard6 liquid and then Audi recommended using the ZF 8 fluid for doing flush since it was an improved version and was backwards compatible.
When I first complained of the issue, the first dealer did a flush and used 8 of the G055162A2.
Sub-sequentially, with the TQ converter replacement, they used 4 of the G060162A2 fluid.
And then recently I did a flush, used ZF LifeGuard8 (4.5 liters) - and I can easily reproduce the problem.
Replacing the fluid does not solve the problem.
Correct. The fluid upgrade is compatible and now recommended specially for the 09L (19A) by ZF per Audi NA. Anyone doing an ATF oil change without a flush and proper drain by disconnecting the return line is only changing half the factory fill anyway.
#30
