'04 A6 3.0 - Red Oil Pressure Light On and Off
Old 07-03-2011, 02:59 PM
DonSandro's Avatar
Originally Posted by SloopJohnB@mac.com
DID YOU ACTUALLY CHECK THE OIL PRESSURE WITH A MECHANICAL GAUGE?
If you didn't you have no idea whether you have an oil pressure or sender problem.
Dropping the pan can be useless although a fun exercise in cleaning sludge out of the pan.
Hi SloopJohnB,
I didn't actually check it but when I brought it to the Audi dealer they did and said there wasn't an issue and the pressure was good. However, I can see the value in checking that again considering what I'm seeing is intermittent. What is the best way to do that? I saw you said tap into the oil pressure area, but would I simply remove the current oil pressure sensor and put this in line? Is there any particular gauge I should get or will any do?
Let's say the oil pressure is fine, what would be the next thing to do? I just want to look at this from all angles.
Thanks again
Old 07-03-2011, 04:49 PM
SloopJohnB@mac.com's Avatar
If the oil pressure is fine then the idiot light is incorrectly lighting up.
The oil pressure sender tells the idiot light to light up.
Replace the oil pressure switch in that case.
Yes, the easiest way is to remove the oil pressure sender and put in an adaptor/fitting for the mechanical oil pressure gauge. You need to know the metric size and thread of the sender to get the correct adapter for the mechanical oil pressure gauge.
Old 07-10-2011, 05:07 PM
DonSandro's Avatar
Default Finally!!!
I finally had the time to do the work.
Oil pressure is fine.
Replaced oil pressure sensor with a new one from Audi (although they did give me the wrong one the first time).
I've put about 75 miles with no light... I'm keeping my fingers crossed.
Thanks again for the help!
Sandro
torturebori
34
06-24-2022 12:43 AM
Henry Stark
A6 (C8 Platform) Discussion
03-15-2019 12:58 PM
lgranch1
Audi 100 / A6 (C4 Platform)
02-06-2009 11:02 PM
HLN
11-13-2006 02:43 AM
EXJ669
10-10-2003 04:59 AM
Quick Reply: '04 A6 3.0 - Red Oil Pressure Light On and Off
