What Tire size should i get for 18 x 8.5 rims ?
Old 02-01-2004, 07:32 AM
Elder Member
meem's Avatar
i thought those were 7.5" wide. where did you read 8.5"?
Old 02-01-2004, 07:33 AM
TTear's Avatar
Local shop wants to get rid off stocked 245/45s IMO. Go with 225/40.
Old 02-01-2004, 07:37 AM
N_H_D's Avatar
Default Re: 245/45?! you sure he didn't mean 245/40?
<center><img src="http://pictureposter.audiworld.com/21264/faisal_047copy.jpg"></center><p>These are 245/45 on 18 x 8 i think (The TT ) , the tires im asking for are for the momo rims , i think the Oettinger REs are 18x8 and thats the tire size thats installed .
Old 02-01-2004, 07:39 AM
TTear's Avatar
Default The guy is so full of crap. What kind of a stupid dimension is that? It'll throw totally off aspect
ratios. Sidewall will be a lot bigger. Jesus, what an a$$.
Old 02-01-2004, 07:41 AM
Thorsholm A4 tdi's Avatar
225/40 or 235/40
Old 02-01-2004, 07:44 AM
Elder Member
meem's Avatar
good to see you around :-)
Old 02-01-2004, 07:45 AM
Default and treadwidth is measured from the beginning of the tread om the sidewall over the tire and down...
... to the end of the tread on the sidewall on the other side of the tire
therefor the treadwidth should be a bit more than the actual width of the rim
  #18
TTear's Avatar
Default 245/45 is totally wrong. It will cause faulty speedo reading, and throw off aspect ratios. Look link
and calculate. The sidewall will be to big compared with your stock tires, and that's catastrophic.<ul><li><a href="http://www.miata.net/garage/tirecalc.html">http://www.miata.net/garage/tirecalc.html</a</li></ul>
Old 02-01-2004, 07:48 AM
  #19
I'm pretty much always around, just not always posting
Old 02-01-2004, 08:01 AM
  #20
Default that's odd. usually car companys put on tires that are a bit too wide...
... cus' the ride gets smoother, especially on larger rims
Quick Reply: What Tire size should i get for 18 x 8.5 rims ?
