Suspension Air Leak Troubleshooting
Old 11-08-2011, 04:14 AM
  #21
Edd W's Avatar
I reckon your car will take UK parts - seeing as you have the good sense to drive on the correct side of the road etc...!
Old 11-08-2011, 10:44 AM
  #22
RKWA8's Avatar
Default Do you want to sell your extra rebuilt strut?
Old 11-09-2011, 06:05 PM
  #23
s4master1's Avatar
Default rebuilt
There's nothing to rebuild on an A8 strut, on random cases the air inlet valve o-rings leak but mostly is the bladder at the bottom fold that gets cracked.
this pictures are from an air spring with 72k miles, as everybody can see the strut is already leaking.
Old 11-09-2011, 06:17 PM
  #24
s4master1's Avatar
Default Air spring
Here
Old 11-10-2011, 12:56 AM
  #25
Edd W's Avatar
I thought the A8 unit was a piston in a bore type design and did not have a bladder like the Allroad unit?
Old 11-10-2011, 07:58 AM
  #26
s4master1's Avatar
Default piston
Most people are under that impression but is not.
is same type/design but with an aluminum housing supporting it all around, the bladder material is actually quite thinner than the Allroad unit.
Old 11-10-2011, 01:23 PM
  #27
benpitt's Avatar
I agree S4master1, there's really nothing there to rebuild. I don't know for sure what gets replaced when the strut is rebuilt to be honest. I am assuming the air bellows and any o-rings to complete the seal. The rebuilder mentioned the secondary leak that needed repair was coming from around the bolt that is threaded into the top of the strut. There is a washer and o-ring that is involved and that o-ring evidently failed. Not having the exact OEM supplier or specs of the original size of the o-ring lead to trial and error until the fit was correct. Replacement of the o-ring, sealant and shimming the washer were involved as I understand it.
I also heard from the rebuilder the same thing stated by S4master1 that the other common leak area is around the air inlet valve.
The strut definitely consists of air bellows or bladder. See this link for more info:
http://www.volkspage.net/technik/ssp/ssp/SSP_292.pdf
Old 11-11-2011, 11:24 AM
  #28
s4master1's Avatar
Default Rebuild
makes no sense for that money to have couple of seals replaced.
you still have the old bladder, shock absorber, shock mount, air inlet valve, assembly cover.
there's only 4 seals that can be retrofitted as there's no factory seals available for this purpose, to replace the largest seal one will need to cut the aluminum housing which at that point it would need to be weld back and is not possible as it would melt the bladder and seal.
in this picture shows the seals together.
Old 11-14-2011, 03:25 AM
  #29
benpitt's Avatar
Per his ebay ad the rebuilder at Mercedes Master Tech replaces the:
"All Seals & O-Rings are New and replaces. We use high quality
airbags ( By SuncoreIndustries.com ) and extra strong crimp rings."
If you're just looking at the sum of the parts versus the cost then it probably doesn't makes sense to rebuild. I don't have the technical knowledge, parts supplier or ability to test these struts so it's worth it to me to find a rebuilt strut versus new given the cost of a new strut.
Old 11-14-2011, 02:45 PM
  #30
Mister Bally's Avatar
When mine failed eleven months ago, it was around the inlet connection. New strut (Damper, per Audi parts description) time. Cha-Ching$
Quick Reply: Suspension Air Leak Troubleshooting
