A7 TDI Chemical Leak
Old 04-10-2014, 11:30 AM
dmlanger's Avatar
Default A7 TDI Chemical Leak
Any TDI owners have any Chemical Leaks? Today i discovered there was damage to my concrete floor in my garage. I park the car in the garage every day and back it in. Near the back right of the car i noticed there was some white chemical that looked like it was corroding away at the concrete. Its about 6x12 in size with a whole 3x6 in size and about 1-2" deep. I did a little bit of research and it was suggested that it was some kind of an acid. From what i gathered it could be the Adblue leaked out and all of the water in the adblue evaporated, leaving behind a highly concentrated Urea Acid that eats away at the floor. Anyone else have an issue like this? I dont keep salt, fertilizer or any chemicals other than gas for my lawn mower and extra engine oil in my garage so i've ruled it out to a chemical leaking from the Audi. Here's a picture. https://i.imgur.com/c24gNcK.jpg
Old 04-10-2014, 03:50 PM
tenspeed's Avatar
Sprinkle it with water and add some baking soda. If it's acidic, it will bubble as it is being neutralized.
Cover the area with a old welcome mat, floor mat, cardboard, etc. until you find where it's coming from.
Old 04-11-2014, 10:54 AM
tenspeed's Avatar
I was looking at the Audi 3.0-liter V6 TDI pdf for the TDI engine and came across the section about AdBlue
( http://vwts.ru/engine/cata/pps_94180...system_eng.pdf page 77):
"Reducing Agent AdBlue®
An extremely pure, transparent 32.5% urea/water solution is used as reducing agent, which is marketed in Europe under
the brand name AdBlue® and in the U.S. under the designation Diesel Exhaust Fluid AdBlue®.
The reducing agent is non-toxic, non-combustible, biodegradable, and categorized in the lowest water hazard class. It is
not a hazardous substance or hazardous material.
Reducing Agent Properties
– It freezes at 12°F (-11°C)
– At temperatures of approximately 158 – 176°F (70 – 80°C), the reducing agent decomposes and there can be
objectionable odors due to the development of ammonia
– Because of its unpleasant odor, aged reducing agent can be distinguished from the fresh solution, which is nearly
odorless
– Aged reducing agent or other foreign material added to the tank is recognized by the NOx sensors in the exhaust
system
– Escaping reducing agent crystallizes forming white salts
– The reducing agent has a high penetration ability and reaches the narrowest spaces due to the capillary effect
Reducing Agent AdBlue® Handling
– Use the reducing agent AdBlue® released by Volkswagen/Audi according to Volkswagen standard and DIN 70070.
Foreign media can damage the DeNox system.
– Do not reuse drained reducing agent to prevent impurities.
– The reducing agent should be added to the tank using only the released tools and containers specified by the
manufacturer. The tank cap of the AdBlue® active tank can be opened using the lug wrench from the tool kit."
Old 04-14-2014, 07:35 AM
dmlanger's Avatar
Thanks for that suggestion. It did bubble as it reacted to the baking soda and was able to clean it up in about a half hour. Now i just need to patch up the concrete.
In fact from your suggestion I came up with a method to find the actual leak. I put some baking soda / water in a spray bottle and while the car was up on the lift, i sprayed in small areas near the suspected area, until i saw it react on the car and voila found the leak.
Old 04-14-2014, 07:41 AM
dmlanger's Avatar
Thanks tenspeed for that info.
I'm sure it is 32.5% when it goes in to the tank, however after it leaks out, the water can and will evaporate to a much higher concentration, especially if the cars hot exhaust pipe is parked over where it dripped out and radiating heat.
I can confirm it crystallizes forming white salts and has a high penetration ability.
Old 04-14-2014, 11:48 AM
tenspeed's Avatar
Glad to hear of your success. Frankly I was surprised that the leak caused so much damage to concrete. Perhaps TDI owners should apply concrete sealant to prevent craters.
sergeyk
Audi Original "S" Cars
04-10-2020 01:02 PM
MBW
Q7 MK 1 Discussion
04-21-2018 10:47 AM
knepster1
07-18-2008 07:31 AM
heybuzzz
02-07-2007 04:38 PM
SimonG
07-11-2005 07:04 PM
Quick Reply: A7 TDI Chemical Leak
