SQ5 in winter mode - with Hartmann 19" peelers
Old 11-18-2013, 04:46 PM
JaXeN's Avatar
Originally Posted by JBDinTX
What was the total cost of your set up. I just picked up my SQ5 on Thursday. Been looking for a winter set up. Do they need rings??
Don't have my papers with me, but it was approximately $2.2k , all in.
I basically paid the prices listed on the Hartmann and Tirerack sites respectively, plus shipping to Niagara Falls NY.
Old 11-18-2013, 10:11 PM
JBDinTX's Avatar
Did you need spacers with those wheels
Old 11-19-2013, 04:19 AM
JaXeN's Avatar
No spacers required @ET25, the ET38's reportedly need 5mm spacers.
The wheels are hub centric.
Different bolts are required if you're coming from the 21" SQ5 wheels... Not sure if the same applies if you're coming from the 20".
Old 11-19-2013, 04:58 PM
Dusts4's Avatar
i have 19 x 9.5 et 40 that I test fit and did not have any rubbing, fitted them with 255/50/19 snows. Interesting that the et38 needed spacers. It is a little tight, but the wheel spun freely without rubbing on anything.
Old 11-19-2013, 10:56 PM
JBDinTX's Avatar
Does anyone know if a 20x8.5 5x112 offset ET: 45 hub bore 66.6 work for my SQ5
Old 11-20-2013, 03:42 AM
JaXeN's Avatar
Only way to be 100% sure is to do a test fit, but chances are that it would be a no go.
The bolt pattern and hub bore are fine, but an offset of 45mm on a 8.5 wheel would give you 12mm less clearance than stock. (Assuming identical wheel design profiles)
Very unlikely that it would fit.
Old 11-20-2013, 03:57 AM
JaXeN's Avatar
Probably had a lot to do with the wheel design.
There are a few 19" ET38 wheels on the Hartman site that don't require spacers for that same reason.
Old 11-20-2013, 04:41 AM
  #18
spijun's Avatar
Audi OEM wheels 19" has four models with ET39 and one model ET27
Old 11-20-2013, 07:45 AM
  #19
JBDinTX's Avatar
I really like the this wheel. But if it won't work Thank everyone. I will keep looking
Old 11-20-2013, 08:35 AM
  #20
JaXeN's Avatar
What wheel is it?
If you like it that much, you could always try a test fit... you never know!
Worst case scenario, you could just get some spacers and be good to go.
I've lived with spacers on many of my past cars and they're not that big of a deal.
They were a better soloution than passing up on wheels I really liked. :-)
Quick Reply: SQ5 in winter mode - with Hartmann 19" peelers
