VAG-COM Mods for D4 A8
#21
Thanks for the info. The D4 seems easier than the D3. I have done the following.
Window open/close via remote.
Double chirp when unlocking.
Ability to enter Nav and Phone entries w/o warning screen.
Increase coming home from 20 to 60 seconds.
Enabled needle sweep.
I tried the signal blink one but don't believe it works with LED light option.
I tried changing the ability to rip songs from CD's to the HDD but couldn't find the option in hidden menu.
I enabled the battery level meter in the hidden menu but it didn't show up in any of the Car menus.
These were all on a 2011 A8L.
Kris
Kris
#24
[QUOTE=Jack88;24800522]The answer is you can't. It needs to be done at the dealer, there has to be communication back to Ingolstadt.[/QUOTE
Ok that sucks but guess I'll be making an appointment. Thanks for the quick response!
#27
Thx. I picked up a Ross-Tech VAG-COM and did some mods today. Works great. the only one I can not get to work is lowering the suspension. I'm running version 15.7.1. Looks like the method in lowering the D4 A8 is different that what I found on the forums. However, I finally found where to do it. Issue is I get an error when I adjust the height in mm. I'm increasing the number like on the threads by 15mm but get the error "Request Sequence Error". Any clue?
#28
Ross-Tech: VAG-COM: Suspension Level Control Calibration
#30
Link to every VCDS code you may ever need-
90% of them work for a8 d4 as well
VCDS & Hidden menu: The complete list - Page 3
Golan Remi (10-12-2020)
