Front brake wear uneven question
Well, the pads did not exhibit angled wear
Worn piston side pads indicates the caliper is not sliding on the pins. It slides enough to stop the car but when pressure is released, the piston side pad rides on the rotor instead of backing off.
Angled pad wear indicates that one side is sliding more than the other.
Touch the front wheels after a long drive. If one side is hotter, the brake is dragging. Even well lubricated pins wear out. I just ordered a third set for a 130K mile car.
I ran for 140,000 miles using stock components, not the originals but stock pads and discs, never had this happen. The minute the Akebonos went in, I've had uneven wear on the pads.
I'd agree that stuck caliper causes uneven wear, but I know my calipers are not stuck or binding.
BigBobELK
12-09-2008 04:23 PM
Gray Bush
10-03-2008 01:18 PM
